Deploying Eclipse OSGI Plugin Project to a Running Equinox [message #52526] |
Sat, 05 November 2005 22:50  |
I started up Equinox from Eclipse 3.2 M3:
java -jar org.eclipse.osgi_3.2.0.v20051030.jar -console
I downloaded, installed, and started two bundles from Oscar's Bundle
Repository.
http://oscar-osgi.sourceforge.net/
install reference:file:/projects/osgi/obr/servlet.jar
install reference:file:/projects/osgi/obr/http.jar
I created a new OSGI Plugin Project in Eclipse 3.2M3. I want to create
a servlet application bundle. What is the easiest way to deploy it to
my running Equinox? Do I have to export the jar every time?
Cameron
(Yes, I'm an OSGI newbie.)
Re: Deploying Eclipse OSGI Plugin Project to a Running Equinox [message #52553 is a reply to message #52526] |
Sun, 06 November 2005 15:05   |
I was trying to follow the steps in the "Coding bundles on the Slug
(demo movie)", but I missed a Equinox startup switch "-dev bin" which I
finally noticed in the debug demo movie. Those are excellent demo
moview by-the-way! Would it be possible to "cat ./equinox" for us from
the first demo?
In the Slug Debug Demo, here is the command which I copied down:
cat ./equinox-debug
.../j9/j9/j9
-Xrunjdwp:transport=dt_socket,suspend=y,server=y,address=loc alhost:8082
-Xint -cp /public/eclipse/plugins/org.eclipse.osgi_3.2.0.jar
org.eclipse.core.runtime.adaptor.EclipseStarter -console -noexit -dev bin
What does org.eclipse.core.runtime.adaptor.EclipseStarter do?
It seams to be working now:
viscosity:/projects/osgi ctaggart$ java -jar
org.eclipse.osgi_3.2.0.v20051030.jar -console -dev bin
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.0.v20051030
osgi> install reference:file:/projects/osgi/test
Bundle id is 5
osgi> ss
id State Bundle
5 INSTALLED test_1.0.0
osgi> start 5
Starting to listen for service events.
osgi> ss
id State Bundle
5 ACTIVE test_1.0.0
osgi> stop 5
Stopped listening for service events.
osgi> ss
id State Bundle
5 RESOLVED test_1.0.0
osgi> uninstall 5
osgi> ss
id State Bundle
osgi> close
Cameron
> Repository.
> Cameron
Re: Deploying Eclipse OSGI Plugin Project to a Running Equinox [message #53252 is a reply to message #52553] |
Tue, 15 November 2005 21:01  |
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
"Cameron Taggart" <cameron.taggart@gmail.com> wrote in message
news:dklnmh$poc$1@news.eclipse.org...
> the first demo?
It is the same as equinox-debug but without the debug stuff. (remove all VM
args other than -cp)
> cat ./equinox-debug
> ../j9/j9/j9
EclipseStarter is an embedded lauchner. It has a main() that starts the
framework and kicks off the whole show. Normal Eclipse uses the Main in
startup.jar that does some extra classpath tweaks, command line processing
etc and the calls some API on EclipseStarter.
Glad to see you got it going. Look forward to you reporting some cool stuff
Jeff
> osgi> ss
> id State Bundle
> Bundle id is 5
> osgi> ss
> id State Bundle
> osgi> start 5
> osgi> ss
> id State Bundle
> 5 ACTIVE test_1.0.0
> osgi> stop 5
> osgi> ss
> id State Bundle
> osgi> uninstall 5
> osgi> ss
> id State Bundle
> osgi> close
> Cameron
> > Repository.
> > Thanks,
> > Cameron
FUDForum. Page generated in 0.28837 seconds
