Home » Archived » BIRT » Group By and Aggregate functions possible in SQL?
Group By and Aggregate functions possible in SQL? [message #52516] Tue, 28 June 2005 14:04 Go to next message
Originally posted by: no.spam.com
Does anyone know if there are limitations on SQL in BIRT? In other words,
if working with a flat data source is something like
SELECT Company,SUM(Amount) FROM Sales
GROUP BY Company
even possible?
Re: Group By and Aggregate functions possible in SQL? [message #52544 is a reply to message #52516] Tue, 28 June 2005 15:01 Go to previous messageGo to next message
Originally posted by: dxmedina.west.com
Not sure about flat files. But any odbc connection can be queried using
grouping and functions to generate a data set for the report.
BIRT has its own reporting functions outside of the SQL query submitted to
generate a data set. Given a data set such as a flat file. The BIRT report
can be designed to do grouping and utilize functions such as grouping, sum,
count, etc.
"Mark S." <no@spam.com> wrote in message
news:910d9ed947fbb3a6e3486e6606f69a9b$1@www.eclipse.org...
> GROUP BY Company
> even possible?
Re: Group By and Aggregate functions possible in SQL? [message #52762 is a reply to message #52516] Wed, 29 June 2005 17:18 Go to previous message
If you are interested in the flatfile data source - the query text language
used by that data set is "SQL-like". It doesn't support GROUP BY, WHERE,
ORDER BY etc.
For JDBC data sources, the SQL is passed to the JDBC driver for execution,
so whatever SQL that's valid for your DBMS is supposed in BIRT.
Gary Xue
BIRT Committer
> GROUP BY Company
> even possible?
Previous Topic:PDF reports from webapplication
Next Topic:Problem with rptdesign file
Current Time: Tue Nov 04 00:42:12 EST 2025
Powered by FUDForum. Page generated in 0.03381 seconds
