Home » Modeling » GMF (Graphical Modeling Framework) » How impl "xsd:choice" model constraint ?
| How impl "xsd:choice" model constraint ? [message #52512] |
Wed, 20 September 2006 14:23  |
Originally posted by: tiggo.kan.gmail.com
As illustrated in a tutorial, a simple ocl-based constraint can be
supported in gmfmap model, But I know little about OCL... Just wonder
whether "<xsd:choice>" constraint can be expressed by OCL? If can, GMF
also can generate such codes?
In my semantic model, "<xsd:choice>" is used on a container, which has
such restriction on children.
thanks for any suggestion.
regards / tiggo
| Re: How impl "xsd:choice" model constraint ? [message #52813 is a reply to message #52512] |
Thu, 21 September 2006 08:40   |
Hi tiggo,
GMF does not process <xsd:choice> at all.
Please, check if EMF is able to use xsd:choice elements in EMF validation
mechanism.
If yes, GMF validation involves EMF validators automatically and visualizes
the resulting diagnostics (if validation enabled).
As for expressing it in OCL, in principal you can do it (manually ;)). It
just depends on how complex the constraint is and
whether OCL is straightforward tool for this.
/Radek
"tiggo" <tiggo.kan@gmail.com> wrote in message
news:ees0uk$vf9$1@utils.eclipse.org...
> Hello,
> regards / tiggo
| Re: How impl "xsd:choice" model constraint ? [message #52840 is a reply to message #52512] |
Thu, 21 September 2006 09:19   |
Hi, Tiggo,
I am assuming that an XSD Choice construct will be generated by EMF as a
FeatureMap (Ed correct me if I am wrong). In any case, there will be two
or more EStructuralFeatures (OCL properties) that are mutually exclusive.
If your XSD element definition for <x> has a choice between elements <a>,
<b>, and <c>, then an OCL constraint expressing the choice might look like:
(not a->isEmpty() implies b->isEmpty() and c->isEmpty()) and
(not b->isEmpty() implies a->isEmpty() and c->isEmpty()) and
(not c->isEmpty() implies a->isEmpty() and b->isEmpty())
Or, more succinctly,
Bag{}->including(
a->isEmpty())->including(
b->isEmpty())->including(
c->isEmpty())
= Bag{true, true, false}
HTH,
Christian
tiggo wrote:
> Hello,
> regards / tiggo
| Re: How impl "xsd:choice" model constraint ? [message #52867 is a reply to message #52813] |
Thu, 21 September 2006 09:24   |
--------------020305030703090704000500
Radek,
No, EMF doesn't currently validate "complex" particle constraints. It's
our oldest feature request to do that and I have prototyped an approach
for doing so:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210>
I'm pretty sure OCL could be used to express mutual exclusion type of
constraint. I've asked Christian to have a look at this question and
added the EMFT newsgroup, which is a better place to ask about OCL...
Radek Dvorak wrote:
> Hi tiggo,
> mechanism.
> /Radek
>> Hello,
>> regards / tiggo
<html>
<head>
</head>
Radek,<br>
<br>
It's our oldest feature request to do that and I have prototyped an
approach for doing so:<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210">https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210</a><br>
</blockquote>
added the EMFT newsgroup, which is a better place to ask about OCL...<br>
<br>
<br>
Radek Dvorak wrote:
<blockquote cite="mideeu186$gli$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi tiggo,
mechanism.
/Radek
"tiggo" <a class="moz-txt-link-rfc2396E" href="mailto:tiggo.kan@gmail.com"><tiggo.kan@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:ees0uk$vf9$1@utils.eclipse.org">news:ees0uk$vf9$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hello,
regards / tiggo
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020305030703090704000500--
| Re: How impl "xsd:choice" model constraint ? [message #52894 is a reply to message #52840] |
Thu, 21 September 2006 09:32   |
--------------080507060101000909080209
Christian,
Actually, EMF treats choice effectively the same as sequence (thereby
losing the mutual exclusion constraint); feature maps are only generated
to preserve relative element order and to capture wildcard or
substitution group information. But I think your answer is still
correct (although I'm not sure if isEmpty applies to single valued
features)...
Christian W. Damus wrote:
> Hi, Tiggo,
> Bag{}->including(
> c->isEmpty())
> HTH,
> Christian
> tiggo wrote:
>> Hello,
>> regards / tiggo
<html>
<head>
</head>
Christian,<br>
<br>
generated to preserve relative element order and to capture wildcard or
features)...<br>
<br>
<br>
<blockquote cite="mideeu3gq$uvs$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi, Tiggo,
Bag{}->including(
c->isEmpty())
HTH,
Christian
tiggo wrote:
</pre>
<pre wrap="">Hello,
regards / tiggo
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------080507060101000909080209--
| Re: How impl "xsd:choice" model constraint ? [message #52980 is a reply to message #52894] |
Thu, 21 September 2006 10:10   |
Thanks, Ed, for the clarification.
And, yes, isEmpty() works for scalar features because applying collection
operations (those preceded by '->') to scalars coerces them to Sets of zero
or one member. That was the tricky bit :-)
Christian
Ed Merks wrote:
> Christian,
> features)...
>> Hi, Tiggo,
>> like:
>> Bag{}->including(
>> c->isEmpty())
>> HTH,
>> Christian
>> tiggo wrote:
>>> Hello,
>>> regards / tiggo
| Re: How impl "xsd:choice" model constraint ? [message #53005 is a reply to message #52867] |
Thu, 21 September 2006 10:12   |
Hi, all,
See my reply to the other branch of this thread in the GMF newsgroup (sorry,
should have cross-posted my reply).
Christian
Ed Merks wrote:
> Radek,
> for doing so:
> Radek Dvorak wrote:
>> Hi tiggo,
>> mechanism.
>> visualizes the resulting diagnostics (if validation enabled).
>> Regards,
>> /Radek
>>> Hello,
>>> regards / tiggo
| Re: How impl "xsd:choice" model constraint ? [message #53029 is a reply to message #52980] |
Thu, 21 September 2006 10:14   |
Oops! Demerit point for me. A much more concise (and readable) constraint
would be:
Bag{a->isEmpty(), b->isEmpty(), c->isEmpty()} = Bag{true, true, false}
Christian
> zero
> Cheers,
> Christian
> Ed Merks wrote:
>> Christian,
>> features)...
>>> Hi, Tiggo,
>>> two or more EStructuralFeatures (OCL properties) that are mutually
>>> exclusive. If your XSD element definition for <x> has a choice between
>>> elements <a>, <b>, and <c>, then an OCL constraint expressing the choice
>>> might look like:
>>> Bag{}->including(
>>> c->isEmpty())
>>> HTH,
>>> Christian
>>> tiggo wrote:
>>>> Hello,
>>>> regards / tiggo
| Re: How impl "xsd:choice" model constraint ? [message #53186 is a reply to message #53029] |
Thu, 21 September 2006 13:22  |
Or, even:
Bag{a->notEmpty(), b->notEmpty(), c->notEmpty()}->one(e | e)
Isn't OCL wonderful?
:-D
> would be:
> Christian
>> zero
>> Cheers,
>> Christian
>> Ed Merks wrote:
>>> Christian,
>>> features)...
>>>> Hi, Tiggo,
>>>> a
>>>> Bag{}->including(
>>>> c->isEmpty())
>>>> HTH,
>>>> Christian
>>>> tiggo wrote:
>>>>> Hello,
>>>>> regards / tiggo
Current Time: Sun Nov 09 08:30:58 EST 2025
Powered by FUDForum. Page generated in 0.04261 seconds
