Home » Eclipse Projects » Nebula » CalendarCombo on GTK
| CalendarCombo on GTK [message #52497] |
Sat, 10 May 2008 06:05  |
Originally posted by: mehow.infogenia.pl
Is CalendarCombo widget supposed to work on GTK? When I try it (code
from HEAD) all I get is an empty combo and no calendar. It looks like
the MouseDown event on a button is not reported at all (listener code
inside CalendarCombo class is not called).
Michal
| Re: CalendarCombo on GTK [message #52605 is a reply to message #52578] |
Sun, 11 May 2008 03:29   |
You could use a Virtual Machine like Virtual Box which is free. I'm
using this on OS-X together with the latest Ubuntu and it works great.
Tom
Emil Crumhorn schrieb:
> Thanks for the screenshots and code.
> I agree, that looks absolutely awful. Hopefully I can get GTK running on
> perhaps a live cd and see if I can fix it, as that's definitely nothing I
> could fix "blindly". I'll make an update when I get it fixed.
> Emil
> "Micha³ Tkacz" <mehow@infogenia.pl> wrote in message
> news:g048an$v5d$1@build.eclipse.org...
>> Hello Emil,
>> My code is very simple:
>> Display display = new Display ();
>> Shell shell = new Shell (display);
>> shell.setSize(200, 400);
>> shell.setLayout(new GridLayout());
>> CalendarCombo combo = new CalendarCombo(shell, SWT.READ_ONLY);
>> //combo.setDate(new Date());
>> shell.open();
>> while (!shell.isDisposed())
>> if (!display.readAndDispatch())
>> display.sleep();
>> display.dispose();
>> The problem seems to be related to the fact that MouseDown listener
>> attached to combo in init method is never called, no matter if I click
>> on a button or on a text field.
>> Maybe it's a known SWT limitation on GTK?.
>> Searching...
>> Ok, I found it:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=206682
>> I've been running it on an older version of SWT. It started to work when
>> I switched to a newer version.
>> Unfortunately there seems to be another small problem, which is probably
>> mCombo.setVisibleItemCount(0);
>> is being ignored:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=71262
>> Together with small cell sizes / big fonts (which I suppose can be
>> adjusted using ISettings?) it makes the widget... well... ugly :(
>> (see attached screenshots)
>> Michal
>> Emil Crumhorn wrote:
>>> It has not been tested recently on GTK (after some major changes), and
>>> unfortunately I currently have no way of testing it either as I don't
>>> have a
>>> Linux box available. If you are willing and able and find the error
>>> please
>>> send me any info and I'll implement whatever fix is necessary. Otherwise
>>> I
>>> will just have to get to it when I can test it on GTK.
>>> Could you please post the code you use for creating the CalendarCombo so
>>> I
>>> can see what flags etc you are using?
>>> Thanks,
>>> Emil
>>> news:g03s0n$tlc$1@build.eclipse.org...
>>>> Hi,
>>>> from
>>>> HEAD) all I get is an empty combo and no calendar. It looks like the
>>>> MouseDown event on a button is not reported at all (listener code inside
>>>> Thanks,
>>>> Michal
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: CalendarCombo on GTK [message #54252 is a reply to message #52551] |
Sun, 08 June 2008 06:53  |
Just an update,
I'm trying to resolve this bug on GTK (Ubuntu) and no matter what I do I
can't seem to capture the event that the combo should open (FocusIn doesn't
work the same way at all and MouseDown does not fire over the button). Every
event I've tried fires too late.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150691 would make my life so
much easier for all platforms, but there's zero votes for it so I don't see
that happening, plus it's 2 years old now..
I'll keep trying, but it doesn't look very promising at the moment.
Emil
"Micha
| Re: CalendarCombo on GTK [message #589662 is a reply to message #52497] |
Sat, 10 May 2008 07:20  |
unfortunately I currently have no way of testing it either as I don't have a
Linux box available. If you are willing and able and find the error please
send me any info and I'll implement whatever fix is necessary. Otherwise I
Could you please post the code you use for creating the CalendarCombo so I
Emil
"Micha
| Re: CalendarCombo on GTK [message #589671 is a reply to message #52524] |
Sat, 10 May 2008 09:35  |
--------------050100070407080605060404
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
Hello Emil,
shell.open();
display.sleep();
display.dispose();
Searching...
Ok, I found it:
is being ignored:
Michal
> Emil
> "Micha
| Re: CalendarCombo on GTK [message #589680 is a reply to message #52551] |
Sat, 10 May 2008 15:11  |
Emil
"Micha
| Re: CalendarCombo on GTK [message #589687 is a reply to message #52578] |
Tom
> Emil
>> Hello Emil,
>> shell.open();
>> display.sleep();
>> display.dispose();
>> Searching...
>> Ok, I found it:
>> is being ignored:
>> Michal
>>> have a
>>> please
>>> I
>>> I
>>> Thanks,
>>> Emil
>>>> Hi,
>>>> from
>>>> Thanks,
>>>> Michal
| Re: CalendarCombo on GTK [message #589699 is a reply to message #52605] |
Sun, 11 May 2008 05:31  |
Thanks Tom, great idea, I'll check that out. Got OS X and Windows currently,
so only one missing =)
Emil
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:g06791$ggd$1@build.eclipse.org...
> You could use a Virtual Machine like Virtual Box which is free. I'm using
> Tom
>> Regards,
>> Emil
>> "Micha
| Re: CalendarCombo on GTK [message #590344 is a reply to message #52551] |
Just an update,
Emil
"Micha
Current Time: Sat Nov 08 16:20:53 EST 2025
Powered by FUDForum. Page generated in 0.04556 seconds
