Home » Newcomers » Newcomers » Diagnostics being swallowed - how to see details?
Diagnostics being swallowed - how to see details? [message #52425] Fri, 15 April 2005 11:16 Go to next message
I'm writing an editor.
It initialises OK (gets to the end of the init() method), but when I
open a document, it displays on the console:
Unhandled event loop exception
Reason:
Failed to execute runnable (java.lang.NoClassDefFoundError)
There is no stack trace, so I can't tell where it is having problems.
Is there any way of suppressing/changing the Eclipse error handling so
I can see the entire exception?
Or is there some other suitable debugging technique to solve such problems?
Many thanks,
Benedict
Re: Diagnostics being swallowed - how to see details? [message #52607 is a reply to message #52425] Fri, 15 April 2005 16:37 Go to previous messageGo to next message
You can try adding a java Exception Breakpoint. In the Breakpoint view
click on the exclamation mark icon that has the J beside it, and then
select the Exception you want to break at.
> Reason:
> Many thanks,
> Benedict
Re: Diagnostics being swallowed - how to see details? [message #52634 is a reply to message #52607] Fri, 15 April 2005 17:19 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Have you looked in the .log file in the .metadata directory of your
runtime workbench. This should contain the stack trace associated with
the exception.
>> Reason:
>> Many thanks,
>> Benedict
Re: Diagnostics being swallowed - how to see details? [message #53001 is a reply to message #52425] Sat, 16 April 2005 22:38 Go to previous message
Originally posted by: Chris_Laffra.ca.ibm.com
Try "Show > View... > Error Log".
Chris Laffra, http://eclipsefaq.org
"benedict heal" <bh@benedictheal.com> wrote in message
news:d3om9l$6ch$1@news.eclipse.org...
> Reason:
problems?
> Many thanks,
> Benedict
Previous Topic:How to create jsp files and HTML files
Next Topic:I'm new to eclipse!
Current Time: Thu Nov 06 14:43:32 EST 2025
Powered by FUDForum. Page generated in 0.08017 seconds
