Home » Archived » XML Schema Definition (XSD) » xsdSchema.load() throws 'NullpointerException"! Help!1
| xsdSchema.load() throws 'NullpointerException"! Help!1 [message #52439] |
Mon, 06 September 2004 03:36  |
Originally posted by: annasser.breathe.com
Am using the XSD Schema Infoset Model (.jar) lib on a Windows XP box ( No
Eclipse installed) but attempting to load a schema throws A
nullpointerException, containg reconcileAttributes() bla bla..
I could not do anything else, even when I try using OpenXSD.jar, same.
Any help colleagues?
Anne
| 'NullpointerException"! - SOLVED!!! [message #52560 is a reply to message #52533] |
Tue, 07 September 2004 00:14   |
Hi All,
Now am using the XSD infoset Model at a rocket speed!! It seems like this
'NullPointerException' rooted at /**
org.eclipse.xsd.impl.XSDSchemaImpl.reconcileAttributes
(SDSchemaImpl.java)**/
is a serious problem for developers using the XSD model as standalone.
Once of the root causes of this is the incompitibility of the xmlParser
shipped with sun 1.4.* jdk or j2re. For those of you out there who might
be experiencing this problem, here is the solution:
1) You need to override the parser shipped with Sun's Java2 jdk or j2re:
a) Download your favorite uptodate DOM Level 2+ xmlPaser such as
xercesJ-2.* etc.
Anne wrote:
> Merks,
> Sorry, and thanks for your thread. Here is the NullpointerException
> stackTrace.
> java.lang.NullPointerException
> at
org.eclipse.xsd.impl.XSDSchemaImpl.reconcileAttributes(XSDSc hemaImpl.java:1877)
> at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.reconcile(XSDC oncreteComponentImpl.java:947)
> at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.changeAttribut e(XSDConcreteComponentImpl.java:1228)
> at
> org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2223)
> at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1201)
> at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElementGen( XSDConcreteComponentImpl.java:2793)
> at
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElement(XSD ConcreteComponentImpl.java:2825)
> at org.eclipse.xsd.impl.XSDSchemaImpl.setElement(XSDSchemaImpl. java:2346)
> at
> org.eclipse.xsd.impl.XSDSchemaImpl.createMetaSchema(XSDSchem aImpl.java:480)
> at
org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSD ResourceImpl.java:505)
> at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:404)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:867)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
> at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:247)
> at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:262)
> at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
> at
org.eclipse.xsd.impl.XSDSchemaImpl.getMagicSchemaForSchema(X SDSchemaImpl.java:532)
> at
> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:609)
> at org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:420)
> at org.eclipse.xsd.util.XSDParser.getSchema(XSDParser.java:291)
> at
com.k_int.schema.SchemaAnalyser.populateSchemaAnalysis(Schem aAnalyser.java:125)
> at damix.SchemaAnalysisTest.main(SchemaAnalysisTest.java:114)
> Anne
> Ed Merks wrote:
> > Anne,
> > Good help is directly proportional to the details you provide. If you
> > have an exception, and a question about it, you should show the stack
> > trace. Which jars are you using? Have you included xsd.resources.jar?
> > Have you looked at the FAQ about your problem? Have you tried (looking
> > at or running) the sample code in org.eclipse.xsd.test? Maybe you need
> > to register the resource factory as in the sample.
> > >Anne
| 'NullpointerException"! - SOLVED!!! [message #52589 is a reply to message #52533] |
Hi All,
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
| 'NullpointerException"! - SOLVED!!! [message #52617 is a reply to message #52533] |
Tue, 07 September 2004 00:22   |
Hi All,
xercesJ- 2.* etc.
b) Assuming <Java-Home> is where you installed java2 jdk or j2re.
i) For jdk - Create a directory called 'endorsed' under
<Java-Home>\lib for j2re create the 'endorsed' directory should be created
under <Java-Home>\jre\lib.
ii) Put all the xmlParser implementation jar files under the
'endorsed' directory.
ii) Also add the jar files to your class path.
NB: Make sure that you do not include any other xmlPasers in your
classpath.
c) Register a new resource Factory as in
org.eclipse.xsd.test.XSDMainTest.java.
DONE!!
cheers
Anne
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
| Sorry, Two threads were a mistake!! Consider the bottom one! [message #52645 is a reply to message #52533] |
Tue, 07 September 2004 00:24  |
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
| Re: xsdSchema.load() throws 'NullpointerException"! Help!1 [message #591404 is a reply to message #52439] |
Mon, 06 September 2004 08:31  |
Anne,
>Anne
| Re: xsdSchema.load() throws 'NullpointerException"! Help!1 [message #591427 is a reply to message #52476] |
Mon, 06 September 2004 22:01  |
Merks,
stackTrace.
Anne
Ed Merks wrote:
> Anne,
> >Anne
| 'NullpointerException"! - SOLVED!!! [message #591435 is a reply to message #52533] |
Hi All,
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
| 'NullpointerException"! - SOLVED!!! [message #591449 is a reply to message #52533] |
Hi All,
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
| 'NullpointerException"! - SOLVED!!! [message #591459 is a reply to message #52533] |
Hi All,
xercesJ- 2.* etc.
classpath.
DONE!!
cheers
Anne
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
| Sorry, Two threads were a mistake!! Consider the bottom one! [message #591471 is a reply to message #52533] |
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
Current Time: Mon Oct 27 19:57:01 EDT 2025
Powered by FUDForum. Page generated in 0.06256 seconds
