Home » Archived » EPF » Structure of entry to XSL under plugins\library\layout
Structure of entry to XSL under plugins\library\layout [message #52416] Tue, 29 July 2008 09:56
I want to customize the contents of my Publish out of EPF composer. So,
I'm working on changing my XSL under my folder:
epf-composer\plugins\org.eclipse.epf.library_1.2.0.v20080312 -1137\layout\xsl
But, I realize that the Entry files to those XSL style sheets are
different from the XMI files under my Library folder.
Can someone tell me where can I access to those Entry files to XSL?
And what is the structure of those Entry files?
And I've got another question, always about customizing my style sheets.
I've got one process "PROCESS A" for example, with a descriptor that we'll
call "ROLEDESCRIPTOR". Is is possible to display Associated Guidance of my
"PROCESS A" in my "ROLEDESCRIPTOR" html page?
Thank you for you help :)
Ms.Hampshire
Previous Topic:Cannot visualize my Activity Diagram
Next Topic:Structure of entry to XSL under plugins\library\layout
Current Time: Fri Jul 25 09:45:05 EDT 2025
Powered by FUDForum. Page generated in 0.06286 seconds
