Home » Newcomers » Newcomers » Problems with new eclipse installation
Problems with new eclipse installation [message #52362] Fri, 15 April 2005 11:02
Originally posted by: sumitb.web.de
I've successfully (?) installed eclipse on my machine. But when I start
it, I get an error message which seems to be related to my CLASSPATH.
It is the following error in the log file:
"!SESSION Apr 15, 2005 12:34:23.442
eclipse.buildId=M200503110845
java.fullversion=GNU libgcj 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)
BootLoader constants: OS=linux, ARCH=amd64, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Apr 15, 2005 12:34:23.443
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: while resolving class:
org.eclipse.core.runtime.adaptor.EclipseAdapto
r
at java.lang.VMClassLoader.resolveClass(java.lang.Class)
(/usr/lib64/libgcj.so.5.0.0)
at java.lang.Class.initializeClass() (/usr/lib64/libgcj.so.5.0.0)
at java.lang.Class.forName(java.lang.String, boolean,
java.lang.ClassLoader) (/usr/lib64/libgcj.so
5.0.0)
at org.eclipse.core.runtime.adaptor.EclipseStarter.createAdapto r()
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(java .lang.String[],
java.lang.Runnable)
(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(java.lan g.String[],
java.lang.Runnable) (Un
known Source)
at _Jv_CallAnyMethodA(java.lang.Object, java.lang.Class, _Jv_Method,
boolean, boolean, java.lang.C
lass[], jvalue, jvalue, boolean) (/usr/lib64/libgcj.so.5.0.0)
boolean, java.lang.Class[], j
ava.lang.Object[]) (/usr/lib64/libgcj.so.5.0.0)
at org.eclipse.core.launcher.Main.basicRun(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.run(java.lang.String[]) (Unknown
Source)
at org.eclipse.core.launcher.Main.main(java.lang.String[]) (Unknown
Source)
Caused by: java.lang.ClassNotFoundException:
org.xml.sax.helpers.DefaultHandler not found in [file:/u
sr/local/eclipse/plugins/org.eclipse.osgi_3.0.1/core.jar,
file:/usr/local/eclipse/plugins/org.eclipse
osgi_3.0.1/console.jar,
file:/usr/local/eclipse/plugins/org.eclipse.osgi_3.0.1/osgi. jar,
file:/usr/l
ocal/eclipse/plugins/org.eclipse.osgi_3.0.1/resolver.jar,
osgi_3.0.1/defaultAdaptor.jar,
file:/usr/local/eclipse/plugins/org.eclipse.osgi_3.0.1/eclip seAdaptor
jar]
at java.net.URLClassLoader.findClass(java.lang.String)
at java.lang.ClassLoader.loadClass(java.lang.String, boolean)
at _Jv_FindClass(_Jv_Utf8Const, java.lang.ClassLoader)
at _Jv_ClassReader.handleClassBegin(int, int, int)
at _Jv_ClassReader.parse() (/usr/lib64/libgcj.so.5.0.0)
at _Jv_DefineClass(java.lang.Class, byte[], int, int)
at java.lang.VMClassLoader.defineClass(java.lang.ClassLoader,
java.lang.String, byte[], int, int,
java.security.ProtectionDomain) (/usr/lib64/libgcj.so.5.0.0)
at java.lang.ClassLoader.defineClass(java.lang.String, byte[], int,
int, java.security.ProtectionD
at java.security.SecureClassLoader.defineClass(java.lang.String ,
byte[], int, int, java.security.C
odeSource) (/usr/lib64/libgcj.so.5.0.0)
at _Jv_PrepareCompiledClass(java.lang.Class)
at _Jv_WaitForState(java.lang.Class, int) (/usr/lib64/libgcj.so.5.0.0)
at java.lang.VMClassLoader.linkClass0(java.lang.Class)
...10 more
!SESSION Fri Apr 15 12:34:23 GMT-01:00 2005
!ENTRY org.eclipse.core.launcher 4 0 Apr 15, 2005 12:34:23.508
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at java.lang.Object.getClass() (/usr/lib64/libgcj.so.5.0.0)"
The system is RedHat ES 4, amd-64 binaries.
Thanks for any hint,
Sumit
Previous Topic:button.setEnabled(false) - how to control the button image?
Next Topic:Launching Eclipse
Current Time: Fri Nov 07 08:27:23 EST 2025
Powered by FUDForum. Page generated in 0.07400 seconds
