MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #52301] |
Fri, 03 September 2004 15:04  |
Originally posted by: robinnt.us.ibm.com
I have created an XSDSchema and am trying to add a global element
(XSDElementDeclaration) to it when the MissingResourceException is thrown as
shown. I can see that the plug-in org.eclipse.xsd has a plugin.properties
file in the eclipse\plugins\org.eclipse.xsd_2.0.1 directory. I am using the
xsd-SDK-M200407211027 build.
java code throwing the exception:
schema.getContents().add(anElement);
java.util.MissingResourceException: Missing properties:
at org.eclipse.emf.common.EMFPlugin.getBaseURL(EMFPlugin.java:1 17)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:687)
at org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2020)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1465)
org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching (XSDSchemaImpl.j
ava:1448)
at org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1747)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentIm
pl.java:1122)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(Notificati
onChainImpl.java:113)
onChainImpl.java:101)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingList
Impl.java:288)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 84)
Has anyone seen this problem and know what is wrong?
Thanks.
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #52406 is a reply to message #52328] |
Sat, 04 September 2004 08:43  |
--------------010809000009010709080408
Content-Type: text/plain; charset=us-ascii; format=flowed
Robin,
The xsd.resources.jar is needed only for standalone execution so it
shouldn't be in the plugin.xml.
Robin Noble-Thomas wrote:
>The problem turned out to be that the xsd.resources.jar file was not in the
>classpath. After adding it to the classpath the error was gone. Should the
>xsd.resources.jar have been listed in the plugin.xml file?
>"Robin Noble-Thomas" <robinnt@us.ibm.com> wrote in message
>news:chaeva$aqt$1@eclipse.org...
>>Hi,
>as
>the
>>at
>>at
>>at
>>ava:1448)
>>at
>>at
>>pl.java:1122)
>>at
>>at
>>at
>>Impl.java:288)
>>Thanks.
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Robin,<br>
<br>
shouldn't be in the plugin.xml.<br>
<br>
<br>
Robin Noble-Thomas wrote:<br>
<blockquote cite="midchaltq$l4t$1@eclipse.org" type="cite">
<pre wrap="">The problem turned out to be that the xsd.resources.jar file was not in the
"Robin Noble-Thomas" <a class="moz-txt-link-rfc2396E" href="mailto:robinnt@us.ibm.com"><robinnt@us.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:chaeva$aqt$1@eclipse.org">news:chaeva$aqt$1@eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->as
</pre>
<pre wrap="">shown. I can see that the plug-in org.eclipse.xsd has a plugin.properties
</pre>
</blockquote>
<pre wrap=""><!---->the
</pre>
<pre wrap="">xsd-SDK-M200407211027 build.
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaInstance(XSDSche maImpl.java:687)
</pre>
<pre wrap="">at
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2020)
</pre>
<pre wrap="">at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1465)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching (XSDSchemaImpl.j
</pre>
<pre wrap="">ava:1448)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1747)
</pre>
<pre wrap="">at
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentIm
</pre>
<pre wrap="">pl.java:1122)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(Notificati
</pre>
<pre wrap="">onChainImpl.java:113)
</pre>
</blockquote>
</pre>
<pre wrap="">onChainImpl.java:101)
</pre>
</blockquote>
<pre wrap=""><!----> org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingList
</pre>
<pre wrap="">Impl.java:288)
Thanks.
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------010809000009010709080408--
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #591335 is a reply to message #52301] |
Fri, 03 September 2004 17:02  |
as
the
> at
> at
> at
> ava:1448)
> at
> at
> pl.java:1122)
> at
> at
> at
> Impl.java:288)
> Thanks.
Re: MissingResourceException: Missing properties: org/eclipse/xsd/plugin.properties [message #591372 is a reply to message #52328] |
Robin,
>>Hi,
>as
>the
>>at
>>at
>>at
>>ava:1448)
>>at
>>at
>>pl.java:1122)
>>at
>>at
>>at
>>Impl.java:288)
>>Thanks.
<html>
<head>
<title></title>
</head>
Robin,<br>
<br>
<br>
<br>
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
<pre wrap="">at
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
<pre wrap="">at
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
Thanks.
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.05690 seconds
