| Eclipse for Linux on PPC (Macintosh)? [message #52257] |
Fri, 11 April 2003 04:59  |
Originally posted by: harry.kranz.web.de
is there a version for the Debian Linux on a PowerPC (Macintosh G4)? Or
can I simply compile the source code for a particular, different plattform?
Thank you very much for your help!
Kind regards,
Henry
| Re: Eclipse for Linux on PPC (Macintosh)? [message #52309 is a reply to message #52257] |
Fri, 11 April 2003 11:06  |
Originally posted by: burner.zclipse.org
On Fri, 11 Apr 2003 08:59:59 +0000, Henry wrote:
> plattform? Thank you very much for your help!
This is not quite the correct newsgroup for such a post (you should use
eclipse.tools), but to answer your question, I would expect that you would
be able to grab the source and build it. The old way (before the carbon
port) to run eclipse on OS/X was to use compile swt against fink's gtk2,
os it _should_ work, though there may be a thing or two that needs to be
hacked.
mike
> Kind regards,
> Henry
| Re: Eclipse for Linux on PPC (Macintosh)? [message #592864 is a reply to message #52257] |
hacked.
mike
> Kind regards,
> Henry
FUDForum. Page generated in 0.04356 seconds
