| CertPathBuilderException from Plugin [message #52245] |
Thu, 26 March 2009 21:21   |
Eclipse User  |
I'm developing an Eclipse plugin that makes a REST call over https.  The
SSL certificate on the server is not valid, changes frequently, and and
will remain that way.  To compensate, I have added the following code,
which works when I run test cases (outside of the Eclipse plugin
environment).
Security.addProvider(new MyProvider());
Security.setProperty("ssl.TrustManagerFactory.algorithm",TrustAllCertificates ");
When I run the code as an eclipse plugin, I get I long stack trace, at the
bottom of which is:
Caused by: java.security.cert.CertPathBuilderException: unable to find
valid certification path to requested target
 com.ibm.security.cert.PKIXCertPathBuilderImpl.buildCertPath( PKIXCertPathBuilderImpl.java:379)
 com.ibm.security.cert.PKIXCertPathBuilderImpl.engineBuild(PK IXCertPathBuilderImpl.java:195)
	at  java.security.cert.CertPathBuilder.build(CertPathBuilder.jav a:215)
	at com.ibm.jsse2.util.f.b(f.java:80)
	... 31 more
The stack trace is the same as the one I get when I don't include the
compensating code and run as a test. Why am I getting different results in
the plugin environment?  Are there any workarounds?
FUDForum. Page generated in 0.05304 seconds
