Reuse XML editor? [message #52215] |
Mon, 08 November 2004 02:09  |
Originally posted by: danh.systinet.com
I have a Eclipse plugin's multipage editor which includes XML editable page.
Can I reuse XML editor of WTP into my XML editor page ( syntax highlight,
code assist,...) ?
Re: Reuse XML editor? [message #52609 is a reply to message #52556] |
Mon, 08 November 2004 21:02   |
WTP is too big, my plugin just need XML text editor. Is there any plan to
distribute WTP into seperate package ( such as XML text editor package, HTML
editor package, etc.)
Danh
"Craig Salter" <csalter@ca.ibm.com> wrote in message
news:cmouri$kol$1@eclipse.org...
> I should point out that the multipage editor in the xsd editor plugin was
> added as a stop gap until the xml editor plugin provides such a class.
> According to David Williams, they will be providing the 'official'
> multipage editor class within the next few days. So keep your eyes open
> for that.
> Dave Carlson wrote:
> > There should not be any problem doing this. For example, look at the
> > XSDEditor which includes an XSDTextEditor that extends
> > org.eclipse.wst.xml.ui.StructuredTextEditorXML, and then includes it in
a
> > multi-page editor along with a graphical view.
> > Regards,
> > Dave Carlson
> > "Ung Thanh Danh" <danh@systinet.com> wrote in message
> > news:cmn61p$uhu$1@eclipse.org...
> >>page.
highlight,
> >> code assist,...) ?
Re: Reuse XML editor? [message #52799 is a reply to message #52609] |
Tue, 09 November 2004 10:58  |
HTML
>Thanks,
>Danh
There's no plan that I know of to distribute WTP this way. But the beauty
of Eclipse is everything is a plugin so you can just install the
components you need. In your case you will need the XML editor and its
prerequisites (such as the sse - structured source editing - plugins). If
you're interested in validation you can pick up the XML validator (which
will be available this week) and the validation framework it depends on.
Lawrence
FUDForum. Page generated in 0.09622 seconds
