Home » Archived » Memory Analyzer (MAT) » OQL Parser
OQL Parser [message #4619] Fri, 05 September 2008 03:29 Go to next message
Executed Query:
SELECT * FROM com.filenet.is.ra.cci.FN_IS_CciConnection isra
Problem reported:
Encountered "is" at line 1, column 27.
Was expecting:
<IDENTIFIER> ...
somehow the .is. makes troubles
Re: OQL Parser [message #4757 is a reply to message #4619] Fri, 05 September 2008 05:01 Go to previous message
Try...
SELECT * FROM "com.filenet.is.ra.cci.FN_IS_CciConnection" isra
(this interprets it as regular expression, but should help you for now)
I have to look into the javacc grammar. There seems to be a problem.
Andreas.
Previous Topic:Exploring all GC roots in dump
Next Topic:Performing initial analysis/conversion using command line tool
Current Time: Sat Nov 08 17:57:04 EST 2025
Powered by FUDForum. Page generated in 0.02979 seconds
