Home » Newcomers » Newcomers » Print button deactivated
Print button deactivated [message #52204] Fri, 15 April 2005 03:35 Go to next message
Originally posted by: twaroch.geoinfo.tuwien.ac.at
Dear Group,
Just downloaded the Eclipe 3.0.2, including the plugin for Haskell support
for the ghc-compiler and installed it on a SUSE Linux 9.1. Everything
seems to work fine right now, only the print button is deactivated.
I can print from other applications, is there some library missing or a
special plugin necessary ?
Thanks for any hint,
Florian
Re: Print button deactivated [message #52233 is a reply to message #52204] Fri, 15 April 2005 04:26 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
Afaik there are only limited printing support for Linux.
From the SWT Faq:
Q: Why is the Print menu item disabled in Eclipse on Motif?
A: Printing on Motif requires that Xprint be installed on your machine.
A good FAQ regarding Xprint can be found at
http://xprint.mozdev.org/docs/Xprint_FAQ.html
Q: Why is the Print menu item disabled in Eclipse on GTK?
A: Printing on GTK has not been implemented yet. You can use the External
Tools support in Eclipse to print files using lpr or some other printing
utility.
HTH,
Csaba
Florian Twaroch wrote:
> Dear Group,
> Florian
Previous Topic:Minimum files needed for eclipse to run
Next Topic:web services / loginhandler service
Current Time: Mon Nov 10 06:57:38 EST 2025
Powered by FUDForum. Page generated in 0.11454 seconds
