Home » Modeling » TMF (Xtext) » An invalid XML character
An invalid XML character [message #52142] Wed, 17 June 2009 22:11
When I run workflow for a DSL, then I am getting this error.
0 [main] INFO eclipse.emf.mwe.core.WorkflowRunner -
13 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - EMF Modeling
Workflow Engine 0.7.0, Build v200906160748
13 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - (c) 2005-2009
openarchitectureware.org and contributors
13 [main] INFO eclipse.emf.mwe.core.WorkflowRunner - running workflow:
/home/eakarsu/workspace-gal/org.xtext.example.mydsl1/src/org /xtext/example/GenerateMyDsl1.mwe
848 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering
platform uri '/home/eakarsu/workspace-gal'
5819 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory '../org.xtext.example.mydsl1/src-gen'
5819 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
/home/eakarsu/workspace-gal/org.xtext.example.mydsl1/../org. xtext.example.mydsl1/src-gen
5823 [main] INFO e.core.container.CompositeComponent - DirectoryCleaner:
cleaning directory '../org.xtext.example.mydsl1.ui/src-gen'
5823 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning
/home/eakarsu/workspace-gal/org.xtext.example.mydsl1/../org. xtext.example.mydsl1.ui/src-gen
5825 [main] INFO e.core.container.CompositeComponent - Generator
5875 [main] INFO ipse.xtext.generator.LanguageConfig - generating
infrastructure for org.xtext.example.MyDsl1 with fragments :
ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment,
EcoreGeneratorFragment, ParseTreeConstructorFragment,
ResourceFactoryFragment, AntlrDelegatingFragment, JavaValidatorFragment,
JavaScopingFragment, FormatterFragment, LabelProviderFragment,
TransformerFragment, OutlineNodeAdapterFactoryFragment,
JavaBasedContentAssistFragment, DelegatingGeneratorFragment
16296 [main] ERROR enerator.CompositeGeneratorFragment - An invalid XML
character (Unicode: 0xc) was found in the element content:
java.lang.RuntimeException: An invalid XML character (Unicode: 0xc) was
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl$Escape.convert(XM LSaveImpl.java:3280)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.getDatatypeValue( XMLSaveImpl.java:3064)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveDataTypeSingl e(XMLSaveImpl.java:1660)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1247)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2667)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1156)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1017)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2368)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1515)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedSing le(XMLSaveImpl.java:2354)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1509)
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:90)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:592)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:206)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1406)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:993)
org.eclipse.xtext.generator.grammarAccess.GrammarAccessFragm ent.generate(GrammarAccessFragment.java:61)
org.eclipse.xtext.generator.CompositeGeneratorFragment.gener ate(CompositeGeneratorFragment.java:77)
org.eclipse.xtext.generator.LanguageConfig.generate(Language Config.java:68)
at org.eclipse.xtext.generator.Generator.generate(Generator.jav a:264)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generat or.java:80)
org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invok e(AbstractWorkflowComponent.java:118)
org.eclipse.emf.mwe.core.container.CompositeComponent.intern alInvoke(CompositeComponent.java:101)
org.eclipse.emf.mwe.core.container.CompositeComponent.invoke (CompositeComponent.java:86)
org.eclipse.emf.mwe.core.WorkflowRunner.executeWorkflow(Work flowRunner.java:412)
at org.eclipse.emf.mwe.core.WorkflowRunner.run(WorkflowRunner.j ava:292)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:239)
Previous Topic:Matching Unicode characters in the grammar
Next Topic:Error when saving the model
Current Time: Tue Jul 22 12:10:44 EDT 2025
Powered by FUDForum. Page generated in 0.02693 seconds
