Home » Modeling » TMF (Xtext) » Lookahead value of xtext grammar
Lookahead value of xtext grammar [message #52116] Wed, 17 June 2009 22:06 Go to next message
I am stress testing tmf xtext with a little large grammar.
I have to parse it with lookahead value 4 bceause lookahead =1 is not
enough for the nature of grammar.
How can I specify the lookahead value?
Erol Akarsu
Re: Lookahead value of xtext grammar [message #52382 is a reply to message #52116] Fri, 19 June 2009 02:09 Go to previous messageGo to next message
Hi Erol,
If you use the ANTLR parser with Xtext you get an ANTLR v3 parser which
uses an LL(*) parsing algorithm -- i.e. arbitrary lookahead -- so you
shouldn't have to restrict the lookahead. But if you want you can do this
by specifying a nested <options> element to the
XtextAntlrGeneratorFragment in your MWE workflow (in this example I've
also enabled backtracking with memoization):
<fragment
class="de.itemis.xtext.antlr.XtextAntlrGeneratorFragment">
<options k="4" backtrack="true" memoize="true"/>
</fragment>
Hope that helps,
--knut
> Regards
> Erol Akarsu
Re: Lookahead value of xtext grammar [message #871495 is a reply to message #52382] Mon, 14 May 2012 04:47 Go to previous messageGo to next message
How can I specify the lookaheadSSSSS valueSSSSS ?
I personnaly need a lookahead (options {k=1;}) value for each branch of grammar, instead of just root (changing it in mwe2 doesn't cover full grammar but just from root of it)
I don't find a way in order to do that.
stress used : C.g grammar from Terence Parr ( ANTLR=>grammar=>C Preprocessor )
C Hello Word failed on Xtext.
Fail example :
int toto = 45;//failed
int * toto = 45; //correct
Rules failing here :
declarator
	: pointer? direct_declarator
	| pointer
pointer
	: '*' type_qualifier+ pointer?
	| '*' pointer
index.php/fa/9661/0/
Remark for using MyDsl.xtext (my file is attached) : you have one occurence of ")=>" on rule "external_declaration".
For this project, I am based on Xtext Hello Word project.
Remarks for forcing compilation, DO NOT INSERT MyDsl.xtext FILE INTO PROJECT WORKSPACE (Xtext Editor is too low for this large grammar), just modify GenerateMyDsl.mwe2 as it:
//var grammarURI = "classpath:/org/xtext/example/mydsl/MyDsl.xtext"
var grammarURI = "file:///C:\\Users\\freemac\\workspaceSDK\\MyDsl.xtext"
// it permits to edit text outside of Eclipse, without provocate "Xtext Validation" bug (lost of performance, and crash on my poor computer)
fragment = parser.antlr.XtextAntlrGeneratorFragment {
options = AntLrOptionsWithKAsString {
backtrack = true
memoize = true
kAsString = "3"
fragment = parser.antlr.XtextAntlrUiGeneratorFragment {
backtrack = true
memoize = true
kAsString = "3"
Time of compilation : a few more than 3 hours.
Need a fix after : "The code of method specialStateTransition(int, IntStream) is exceeding the 65535 bytes limit", on InternalMyDslParser.java that is a big file, it can be corrected manually by making a sub-function launch that contains cases switch range 0 to 400. It gives somethings like that :
// function to correct
public int specialStateTransition(int s, IntStream _input) throws NoViableAltException {
TokenStream input = (TokenStream)_input;
int _s = s;
if (s<326)
try {
return toto(s);
} catch (TotoException e) {
// TODO Auto-generated catch block
// continue
switch ( s ) {
case 400 :
//... end of current function by there.
//sub-function inserted
private int toto(int s) throws TotoException {
switch (s) {
case 0 :
//.. cases 0 to 399
break;
throw new TotoException();
InternalMyDslParser will be on both org.xtext.example.mydsl and org.xtext.example.mydsl.ui parts of Xtext Hello Word project.
My feels abouts this bug :
k parameter (for lookahead depth), used on mwe2 file, affects only root of grammar.
Note that I used there k=3 on mwe2, using maximum of k value that occurs on C.g
But fact is that sub sub sub rule of C.g don't seem reaching pointer rule.
My project : mamevhdl
Main project is generating main part of VHDL code from C++ code of Mame. Resulting arcade schematics with wires and bottom components (each components empty but with Mame names, helping to normalize of arcade VHDL projects)
I am really new on Xtext and ANTLR.
A frenchy boy,
Renaud Helias
  • Attachment: C.g
    (Size: 10.91KB, Downloaded 242 times)
  • Attachment: MyDsl.xtext
    (Size: 11.63KB, Downloaded 230 times)
  • Attachment: hello_c.jpg
    (Size: 20.06KB, Downloaded 1457 times)
Re: Lookahead value of xtext grammar [message #871968 is a reply to message #871495] Tue, 15 May 2012 04:22 Go to previous messageGo to next message
Hi Renaud,
please double check whether it's really necessary to explicitly pass the
lookahead? Antlr will usually figure that out automagically. Regarding
the bytecode limit you may want to explore the the classSplitting option
in the Antlr options.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 14.05.12 10:47, schrieb Renaud Helias:
> Fail example :
> declarator
> | pointer
> pointer
> | '*' pointer
> backtrack = true
> memoize = true
> kAsString = "3"
> backtrack = true
> memoize = true
> kAsString = "3"
> int _s = s;
> if (s<326)
> try {
> return toto(s);
> // continue
> switch ( s ) {
> case 400 :
> switch (s) {
> case 0 :
> //.. cases 0 to 399
> break;
> A frenchy boy,
> Renaud Helias
Re: Lookahead value of xtext grammar [message #873262 is a reply to message #871968] Thu, 17 May 2012 16:33 Go to previous messageGo to next message
Hi Sebastian,
It seems that there is no magic backtrack/LL(*) occurring in this sorcerer backtrack/LL(k) case.
k and backtrack are used directly on branches for prototyping a grammar (for example coming from a BNF), I think C.g is an evil case for its ANTLR algorithm test.
I thinked that k was only used for performance... damn.
I have done an other test : I compare use of parameters between C.g and my MyDsl.g (the same playing with backtrack/memoize options only at top, and without using k)
If my input file hello.c is :
    /* Hello World program */
    #include<stdio.h>
    int * r=4;
    * main()
    printf("Hello World");
My log output is :
Test de C.g
Test de MyDsl.g backtrack=true memoize=false
Test de MyDsl.g backtrack=true memoize=true
Test de MyDsl.g backtrack=true memoize=false et syntactic predicates
And then if my input file hello.c is :
    #include<stdio.h>
    int r=4;
    main()
My log output is :
Test de C.g
hello.c line 4:9 mismatched input '=' expecting ';'
hello.c line 5:9 no viable alternative at input ')'
hello.c line 6:4 mismatched input '{' expecting ';'
hello.c line 7:11 no viable alternative at input '"Hello World"'
Here attached this basic java project source code (not Xtext)
A frenchy boy,
Renaud
[Updated on: Thu, 17 May 2012 16:45] by Moderator
Re: Lookahead value of xtext grammar [message #873962 is a reply to message #873262] Sat, 19 May 2012 11:54 Go to previous messageGo to next message
Hi Sebastian,
I founded a semantic predicate on C.g, k parameter didn't affect here (k no sense here). I read somewhere that semantic predicate are not implemented on Xtext.
It is ok for me, to compare Xtext/model and ANTLR/semantic-predicates is like comparing DOM and SAX Cool
I think that LL(*) just cover LL(k), with or without using backtrack.
memoize parameter is just a optimisation parameter that didn't have any border effect.
Problem here came just from a special case where ANTLR crap itself :
index.php/fa/9780/0/
a : b c?;
b : ('toto'|IDENTIFIER)+;
c : IDENTIFIER | IDENTIFIER '=';
toto points p=
index.php/fa/9781/0/
Thanks a lot for your help,
Renaud
  • Attachment: toto_points_p_eq.png
    (Size: 16.13KB, Downloaded 1429 times)
  • Attachment: hello_c_ok.png
    (Size: 16.55KB, Downloaded 1462 times)
  • Attachment: MyDsl.g
    (Size: 11.40KB, Downloaded 279 times)
  • Attachment: C.g
    (Size: 10.91KB, Downloaded 173 times)
    (Size: 11.77KB, Downloaded 307 times)
[Updated on: Sat, 19 May 2012 12:54] by Moderator
Re: Lookahead value of xtext grammar [message #873983 is a reply to message #873962] Sat, 19 May 2012 13:16 Go to previous message
Renaud,
please refer to the docs on Xtext's predicates.
I'm not sure exactly what you expect right now. What I got is that you
face some issues with the migration of a rather complex, pure Antlr
grammar to Xtext.
The given snippet is obviously ambiguous since the input
toto points
may either be
a [ b [ 'toto' points ] ]
or
a [ b [ 'toto' ] c [ points ] ]
thus Antlr will give you some warnings if you disable backtracking and
remove some alternatives from your grammar. This leads to the parse
errors for toto points p=.
Sebastian
Am 19.05.12 17:54, schrieb Renaud Helias:
> Hi Sebastian,
> a : b c?;
> toto points p=
> Renaud
Previous Topic:Autocomplete import example
Next Topic:XText 2.3.0M6 problem with setInitializer
Current Time: Mon Nov 03 14:47:51 EST 2025
Powered by FUDForum. Page generated in 0.04569 seconds
