Home » Archived » XML Schema Definition (XSD) » Adding XSD components to an existing schema
| Adding XSD components to an existing schema [message #52057] |
Wed, 01 September 2004 17:27  |
Originally posted by: gj.puredge.com
I want to add a Simple Element declaration to a ModelGroup (sequence). What
I have is the XSDModelGroup object (modelGroup) and the name of the element.
Do I have enough information to add this element or do I need to start with
the Particle of the ModelGroup?
For instance:
void addElementToGroup(XSDModelGroup modelGroup, String elementName)
// user defined function
XSDParticle particle = newXSDElement(elementName, 0, 1);
// add new Element to model group
modelGroup.getContents().add(particle);
Is this enough to update my XSD model or is there something else I need to
do?
Also, in my tree model I'm only storing XSDModelGroup and
XSDElementDeclaration objects. Should I perhaps store the Particles of each
instead or is there a way to determine the "parent" particle from these?
In this example I'm updating the concrete schema. I assume the abstract
representation will work as well after this update. Is that correct?
I hope I'm not being too cryptic.
thanks
Gary
| Re: Adding XSD components to an existing schema [message #52084 is a reply to message #52057] |
Wed, 01 September 2004 17:37   |
Gary,
I've tried to make sure there is an example of how to construct pretty
much everything in XSDPrototypicalSchema.java. What you've outlined
makes sense and should be sufficient. Maybe storing the particles is
better because there can be many particles that have the same element
declaration (model group) as their term. But then again there is a
getContainer reference available for all concrete components, so maybe
that's enough for what you need. And yes, the abstract relations are
populated as you change the concrete ones.
If I couldn't handle cryptic, these newsgroups would have driven me
insane long ago! ;-)
Gary J wrote:
>Hi,
>For instance:
>do?
>thanks
>Gary
| Re: Adding XSD components to an existing schema [message #52109 is a reply to message #52084] |
Wed, 01 September 2004 18:13   |
Thanks Ed,
XSDPrototypicalSchema was a big help.
To summarize the relationships in the concrete model:
elementParticle.getContent() returns the Element declaration
elementParticle.getTerm() returns the abstract Element declaration
elementDeclaration.getContainer() returns the concrete particle
Does the same hold true for a ModelGroup? In other words:
modelGroupParticle.getContent() returns the XSDModelGroup
modelGroupParticle.getTerm() returns the abstract model group
modelGroupDeclaration.getContainer() returns the concrete particle
That's why I would prefer to reference particles rather than
have a mix and match of different objects.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ch5f8n$31u$1@eclipse.org...
Gary,
Gary J wrote:
>Hi,
What
element.
>For instance:
>do?
each
>thanks
>Gary
| Re: Adding XSD components to an existing schema [message #52809 is a reply to message #52109] |
Mon, 13 September 2004 08:02  |
--------------060404060701090703060203
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
Model groups work a little differently because there is a model group
definition component as well as a model group component. At the
concrete level you'll see a model group definition and at the abstract
level, you'll just see the model group.
Gary J wrote:
>Thanks Ed,
>Gary,
>Gary J wrote:
>>Hi,
>What
>element.
>>For instance:
>>do?
>each
>>thanks
>>Gary
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
level, you'll just see the model group.<br>
<br>
<br>
Gary J wrote:
<blockquote cite="midch5hbd$5vv$1@eclipse.org" type="cite">
<pre wrap="">Thanks Ed,
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:ch5f8n$31u$1@eclipse.org">news:ch5f8n$31u$1@eclipse.org</a>...
Gary,
Gary J wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->What
</pre>
<pre wrap="">I have is the XSDModelGroup object (modelGroup) and the name of the
</pre>
</blockquote>
<pre wrap=""><!---->element.
</pre>
<pre wrap="">Do I have enough information to add this element or do I need to start with
For instance:
do?
</pre>
</blockquote>
<pre wrap=""><!---->each
</pre>
<pre wrap="">instead or is there a way to determine the "parent" particle from these?
thanks
Gary
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------060404060701090703060203--
| Re: Adding XSD components to an existing schema [message #591246 is a reply to message #52057] |
Gary,
Gary J wrote:
>Hi,
>For instance:
>do?
>thanks
>Gary
| Re: Adding XSD components to an existing schema [message #591255 is a reply to message #52084] |
Thanks Ed,
Gary,
Gary J wrote:
>Hi,
What
element.
>For instance:
>do?
each
>thanks
>Gary
| Re: Adding XSD components to an existing schema [message #591534 is a reply to message #52109] |
Gary,
Gary J wrote:
>Thanks Ed,
>Gary,
>Gary J wrote:
>>Hi,
>What
>element.
>>For instance:
>>do?
>each
>>thanks
>>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
<br>
Gary,
Gary J wrote:
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
</pre>
For instance:
do?
</pre>
</blockquote>
</pre>
thanks
Gary
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Thu Nov 06 22:11:39 EST 2025
Powered by FUDForum. Page generated in 0.04500 seconds
