Home » Language IDEs » PHP Development Tools (PDT) » How do I _completely_ delete a Project?
How do I _completely_ delete a Project? [message #52043] Sat, 15 September 2007 19:09 Go to next message
Originally posted by: Ned.WordAndDeed.com
I follow the directions in the Help. Simple enough to delete a
project. No errors reported.
When I try to create a new project that uses the same Project Contents
Directory as the deleted project, I get the following error message
from the PHP Project dialog:
C:\htdocs\catalog overlaps the location of another project: 'catalog'
Clearly I haven't deleted the old project completely. What else needs
to be done? Where is this being remembered?
TIA,
Ned
Eclipse 3.3.0
PDT 1.0.0v20070910
Re: How do I _completely_ delete a Project? [message #52093 is a reply to message #52043] Sun, 16 September 2007 03:26 Go to previous messageGo to next message
Originally posted by: Martin.eisengardt.de
IT should be simple. Right click, delete, "Also delete contents". However
this works for me.
If You do not delete contents, Eclipse does not delete this on your HDD but
removes Your project from your workspace. Thats not a PDT specific
behaviour. However. You can recreate this project from HDD by creating a
simple project (General-Simple projet) at the same folder.
If it says something about overlapped folders You are trying to create
something like:
ProjectA: /my/project
ProjectB: /my/project or /my/project/anotherProject
Eclipse does not allow this. Neither Java Developement (JDT) nor PDT. Ensure
Your old project is removed from workspace correctly. and does not show up
any more. You may have to deselect working sets.
Re: How do I _completely_ delete a Project? [message #52680 is a reply to message #52093] Tue, 18 September 2007 11:44 Go to previous message
On Sun, 16 Sep 2007 09:26:14 +0200, "Martin Eisengardt"
Everything should be simple :-)
Thanks, Martin this was the key to my problem.
Ned
Previous Topic:failed openning '../include.inc.php'
Next Topic:Best way to bring existing files & structure into Project & CVS?
Current Time: Wed Dec 03 06:52:56 EST 2025
Powered by FUDForum. Page generated in 0.03481 seconds
