Home » Language IDEs » AspectJ » Aspects across (Eclipse) projects
Aspects across (Eclipse) projects [message #51916] Thu, 19 May 2005 20:16 Go to next message
Originally posted by: dan.haywood-associatesNOSPAM.co.uk
Is it possible - perhaps using INPATH - to get an aspect in one project to
weave classes in another. I'm sure it must be.
I have:
- project1 - holds a library I want to test
- project2 - holds POJO fixtures
- project3 - holds aspects that need to weave the POJOs in #2 to use
library in #1
- project4 - holds the tests
However, the aspects in #3 are not doing any weaving, or so it seems.
As a follow-on, these projects are actually plug-ins. I suspect I'll have
further problems here - any hints?
Many thanks
Dan
Re: Aspects across (Eclipse) projects [message #51968 is a reply to message #51916] Fri, 20 May 2005 12:05 Go to previous message
> I have:
> library in #1
Yes, it is possible. Project 3 can set an inpath setting for the output
directory of project 2. The woven class files should then end up in the
output directory of project 3. You can use the show weave messages option
(under AspectJ Compiler properties > Other) to see what's happening.
Shouldn't be a problem. AJDT itself is a bunch of AspectJ plug-ins. Your
AspectJ-enabled plug-ins should have a dependency on
the org.aspectj.runtime plugin.
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Aspects across (Eclipse) projects [message #588269 is a reply to message #51916] Fri, 20 May 2005 12:05 Go to previous message
> I have:
> library in #1
Matt.
Matt Chapman
Previous Topic:Aspects across (Eclipse) projects
Next Topic:Inpath jar not getting weaved
Current Time: Tue Nov 18 16:57:33 EST 2025
Powered by FUDForum. Page generated in 0.05162 seconds
