Home » Eclipse Projects » Eclipse Platform » Problems With FTP Plugin
Problems With FTP Plugin [message #51867] Wed, 28 May 2003 09:52 Go to next message
Originally posted by: chartjes.littlehart.net
My appologies if this is to the wrong mailing list, but an hour-long dig
through the archives didn't clear it up for me.
I'm using Eclipse 2.1 on a Mandrake Linux 9.1 box, and I've installed the
FTP & WebDAV plugin. I'm using IBM's 1.4 JRE as my Java environment.
Anywho, whenever I try to connect to a server using the FTP plugin (I've
followed the directions on setting up the target for the plugin) it
crashes, giving me the following error:
JVM terminated. Exit code=1
/opt/IBMJava2-14/bin/java
-cp /home/chartjes/eclipse/startup.jar org.eclipse.core.launcher.Main
-os linux
-ws gtk
-arch x86
-showsplash /home/chartjes/eclipse/eclipse -showsplash 600
Any help with this problem would be greatly appreciated.
Chris Hartjes
Hoping To Use Eclipse Instead Of Emacs :)
Re: Problems With FTP Plugin [message #53912 is a reply to message #51867] Thu, 29 May 2003 09:12 Go to previous messageGo to next message
Originally posted by: Michael_Valenta.oti.com
The FTP plugin you are using is of experimental quality. That said, it
shouldn't be causing the VM to crash. You could try another VM and see
what happens.
> -os linux
> -ws gtk
> -arch x86
> Chris Hartjes
Re: Problems With FTP Plugin [message #54666 is a reply to message #53912] Thu, 29 May 2003 14:50 Go to previous messageGo to next message
I switched to using Sun's VM, and it did the same thing. I'm thinking it
may have something to do with Mandrake itself. I run a different Linux
distribution at home so I will it try it there before throwing in the
towel.
Thanks for the help though.
> what happens.
>> -os linux
>> -ws gtk
>> -arch x86
>> Chris Hartjes
Re: Problems With FTP Plugin [message #60303 is a reply to message #54666] Tue, 03 June 2003 09:03 Go to previous message
I *finally* figured out what the problem was. The GTK version keeps
crashing on my system (Mandrake Linux 9.1) but the Motif version works just
fine.
I'm off and running!
Chris
> towel.
>> what happens.
>>> the
>>> -os linux
>>> -ws gtk
>>> -arch x86
>>> Chris Hartjes
Previous Topic:Eclipse 2.1 and RedHat Linux 7.3
Next Topic:searching resources in jar files
Current Time: Thu Nov 27 17:29:27 EST 2025
Powered by FUDForum. Page generated in 0.04073 seconds
