| Problems With FTP Plugin [message #51867] |
Wed, 28 May 2003 09:52  |
Originally posted by: chartjes.littlehart.net
My appologies if this is to the wrong mailing list, but an hour-long dig
through the archives didn't clear it up for me.
I'm using Eclipse 2.1 on a Mandrake Linux 9.1 box, and I've installed the
FTP & WebDAV plugin. I'm using IBM's 1.4 JRE as my Java environment.
Anywho, whenever I try to connect to a server using the FTP plugin (I've
followed the directions on setting up the target for the plugin) it
crashes, giving me the following error:
JVM terminated. Exit code=1
/opt/IBMJava2-14/bin/java
-cp /home/chartjes/eclipse/startup.jar org.eclipse.core.launcher.Main
-os linux
-ws gtk
-arch x86
-showsplash /home/chartjes/eclipse/eclipse -showsplash 600
Any help with this problem would be greatly appreciated.
Chris Hartjes
Hoping To Use Eclipse Instead Of Emacs :)
| Re: Problems With FTP Plugin [message #60303 is a reply to message #54666] |
Tue, 03 June 2003 09:03  |
I *finally* figured out what the problem was. The GTK version keeps
crashing on my system (Mandrake Linux 9.1) but the Motif version works just
fine.
I'm off and running!
Chris
Chris Hartjes wrote:
> I switched to using Sun's VM, and it did the same thing. I'm thinking it
> may have something to do with Mandrake itself. I run a different Linux
> distribution at home so I will it try it there before throwing in the
> towel.
> Thanks for the help though.
> Michael Valenta wrote:
>> The FTP plugin you are using is of experimental quality. That said, it
>> shouldn't be causing the VM to crash. You could try another VM and see
>> what happens.
>>> the
>>> -os linux
>>> -ws gtk
>>> -arch x86
>>> Chris Hartjes
FUDForum. Page generated in 0.05072 seconds
