Home » Language IDEs » ServerTools (WTP) » Dependency on EMF
Dependency on EMF [message #51858] Thu, 04 November 2004 11:45 Go to next message
Are there any plans to remove this dependency? As far as I could tell from a
quick look it was mostly related to some Command classes.
- Richard
Re: Dependency on EMF [message #52271 is a reply to message #51858] Mon, 08 November 2004 09:41 Go to previous messageGo to next message
Richard,
EMF is used to understand the J2EE deployment descriptors (among other
things) by commands, operations, and viewers. So, it is unlikely that this
dependency will be removed. As more code is released into the repository
throughout the cycle, the reason for the dependency will become more
apparent.
Kind Regards,
Michael D. Elder
"Richard Rodseth" <rrodseth@mac.com> wrote in message
news:cmdlun$vm5$1@eclipse.org...
a
> Thanks
> - Richard
Re: Dependency on EMF [message #52825 is a reply to message #52271] Tue, 09 November 2004 11:21 Go to previous messageGo to next message
Thanks. Fair enough. But there seems to be interest in the
StructuredTextEditor class, independent of any J2EE connection.
"Michael D. Elder" <mdelder@us.ibm.com> wrote in message
news:cmo0iv$vsp$1@eclipse.org...
> Richard,
> apparent.
> Kind Regards,
> Michael D. Elder
>> from
> a
>> Thanks
>> - Richard
Re: Dependency on EMF [message #52936 is a reply to message #52825] Tue, 09 November 2004 15:33 Go to previous message
We use that specifically to have a common comand and command stack with
other WTP components. There is work underway in the base Eclipse to
provide a common command and command stack, which we'd move to once
it was available. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=37716
Previous Topic:Xml Catalog
Next Topic:XML editor encoding support
Current Time: Fri Nov 21 08:09:17 EST 2025
Powered by FUDForum. Page generated in 0.04259 seconds
