Home » Archived » Visual Editor (VE) » Where is VE?
Where is VE? [message #51849] Sun, 25 July 2004 12:54 Go to next message
Originally posted by: danmcleran.hotmail.com
I have installed:
eclipse sdk 3.0
gef runtime 3.0
emf-sdo runtime 2.0.0
ve runtime S20040628
When I start eclipse, I don't see any way to create a new visual class.
When I try to add a library to my project, I don't see an option to add
the swt library. Am I missing something? What else could I try to get SWT
working?
Dan McLeran
Re: Where is VE? [message #51877 is a reply to message #51849] Sun, 25 July 2004 13:14 Go to previous messageGo to next message
Dan McLeran wrote:
> I have installed:
> eclipse sdk 3.0
> gef runtime 3.0
> working?
> Dan McLeran
All,
After scouring the message board for similar problems, I saw someone
suggest deleting the configuration dir. I did the following:
1. Shut down eclipse.
2. rename the configuration dir.
3. restart eclipse.
I was then able to add swt as a library.
Is there some guidelines to follow for when to rename/delete the
configuration directory? It seems like a weakness in eclipse. I thought
that eclipse was designed to recognize when plugins/added functionality
had been installed.
Re: Where is VE? [message #51903 is a reply to message #51877] Sun, 25 July 2004 13:22 Go to previous messageGo to next message
Dan,
Have you installed a VE build before this latest stable build? The
configuration issue is due to the VE builds all having the same plug-in
version number (1.0.0). When Eclipse starts up it checks for new
plug-ins and new versions of existing plug-ins. Since these development
builds of VE all have the same version number, it doesn't know that it
has to recache the VE plug-ins info. Removing the configuration
directory forces Eclipse to recache the plug-in info for all installed
plug-ins (including VE).
- Jeff
> All,
> 3. restart eclipse.
> had been installed.
Re: Where is VE? [message #51954 is a reply to message #51877] Sun, 25 July 2004 14:47 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Dan McLeran wrote:
> All,
> 3. restart eclipse.
> had been installed.
It is probably better to use the -clean flag instead of removing the
configuration directory. That flag causes eclipse to clean up and redo
the configuration.
Peter
Re: Where is VE? [message #55295 is a reply to message #51903] Sun, 08 August 2004 23:05 Go to previous message
No, this was my first attempt at installing the VE. I had been using
Eclipse as a Java and C++ IDE, previously. Like I said, after I re-named
the configuration directoy, all is well.
Jeff Myers wrote:
> Dan,
> - Jeff
> > All,
> > 3. restart eclipse.
> > had been installed.
Re: Where is VE? [message #595801 is a reply to message #51849] Sun, 25 July 2004 13:14 Go to previous message
Dan McLeran wrote:
> I have installed:
> eclipse sdk 3.0
> gef runtime 3.0
> working?
> Dan McLeran
All,
3. restart eclipse.
had been installed.
Re: Where is VE? [message #595816 is a reply to message #51877] Sun, 25 July 2004 13:22 Go to previous message
Dan,
- Jeff
> All,
> 3. restart eclipse.
> had been installed.
Re: Where is VE? [message #595834 is a reply to message #51877] Sun, 25 July 2004 14:47 Go to previous message
Dan McLeran wrote:
> All,
> 3. restart eclipse.
> had been installed.
the configuration.
Peter
Re: Where is VE? [message #597027 is a reply to message #51903] Sun, 08 August 2004 23:05 Go to previous message
Jeff Myers wrote:
> Dan,
> - Jeff
> > All,
> > 3. restart eclipse.
> > had been installed.
Previous Topic:[ANNOUNCE]Visual Editor Milestone 2 Available
Next Topic:VE Tabs and Menus
Current Time: Tue Nov 18 06:47:06 EST 2025
Powered by FUDForum. Page generated in 0.05978 seconds
