Home » Eclipse Projects » Technology Project and PMC » Error compiling java file
Error compiling java file [message #51841] Mon, 07 April 2003 15:16 Go to next message
Originally posted by: sole.hotmail.com
When I try to run a java file the console show me the following message:
Error occurred during initialization of VM
java/lang/NoClassDefFoundError: java/lang/Object
I download de jdk 1.3 and in the: Window --> Preferences --> Java -->
Classpath Variables I create the variable JAVA wich point to the jdk\bin
folder.
Can anyone help me??
I don't know what I make wrong...
Re: Error compiling java file [message #51893 is a reply to message #51841] Mon, 07 April 2003 20:11 Go to previous messageGo to next message
Originally posted by: sandumtl.comnet.ca
I hope you don't run a java file but a class file. When seting the
environment, set the following:
set JAVA_HOME=the_path_to_jdk_directory (for instance c:\jdk1.3.1_07)
set CLASSPATH=.;%JAVA_HOME%\lib\tools.jar
set PATH=%PATH%;%JAVA_HOME%\bin
> folder.
Re: Error compiling java file [message #51945 is a reply to message #51841] Tue, 08 April 2003 03:28 Go to previous message
>folder.
I assume that the build path of your project (see project's properties)
does not contain a valid SDK. Where did you read that you have to add a
classpath variable called "JAVA"? This would be wrong doc.
Dani
Re: Error compiling java file [message #592630 is a reply to message #51841] Mon, 07 April 2003 20:11 Go to previous message
> folder.
Re: Error compiling java file [message #592658 is a reply to message #51841] Tue, 08 April 2003 03:28 Go to previous message
>folder.
Dani
Previous Topic:Avoiding huge download of Eclipse 2.1
Next Topic:when hot code replacement fails
Current Time: Tue Jul 22 02:27:59 EDT 2025
Powered by FUDForum. Page generated in 0.04949 seconds
