Using AJDT to debug? [message #51780] |
Wed, 18 May 2005 20:18  |
Originally posted by: jeroen.lightyear.be
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Yesterday i played a bit with the bugdel plugin
(http://www.csg.is.titech.ac.jp/~usui/bugdel/index-e.shtml), which is a
plugin to debug java app's, by using AOP. By example you can simply
invoke a System.out.println() whenever a getter or setter is called.
Since i plan to use Aspects in the feature for other things then just
debugging i'm wondering if something like bugdel is possible with ajdt
in a simple way (in bugdel it's allmost only point-and-click, which is
very sufficient for debugging). I'd rather install only one plugin which
enables all kinds of AOP in Eclipse then having to use 2 or 3 plugins.
Another question: I tried AJDT (1.2.0M3 for Eclipse 3.1M6) on Eclipse
3.1M7 but it doesn't work, is this correct?
Thx!
Jeroen
<TeRanEX/>
--- e-mail: jeroen@lightyear.be - jid: teranex@jabber.org
--- blog: http://budts.be/weblog/ - cv: http://budts.be/jeroen/
--- projects: http://lightyear.be - pgp: 0x8B7B774A
_____________________________________
NO SoftwarePatents in Europe!
See an example: http://webshop.ffii.org/
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCi9toH04wF4t7d0oRAm4uAJ934Zbri336UPF+erV2p3ufhKadTgCe Knrh
A+7e67IS71RvBYaYKBvZe7E=
=FIEu
-----END PGP SIGNATURE-----
Re: Using AJDT to debug? [message #51834 is a reply to message #51780] |
Thu, 19 May 2005 06:04  |
I think it's good there is this kind of choice, rather than trying to have
a single "one size fits all" plugin. Although having an update site for
bugdel, or a packaging of multiple related plugins would make installation
easier for end users. That said, I am all for adding value to AJDT where
it makes sense. We have thought for some time it would be nice to enable
more uses of AOP via wizards and the like - such as being able to select
aspects from a library. So feel free to raise an enhancement request for
some sort of point and click debugging support that could be added to AJDT
- the more detail the better.
Yes, unfortunately that is correct. We're working on getting AJDT working
on Eclipse 3.1M7. We'll release a development build as soon as it's ready.
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Using AJDT to debug? [message #588186 is a reply to message #51780] |
Matt.
Matt Chapman
FUDForum. Page generated in 0.05238 seconds
