| Using AJDT to debug? [message #51780] | Wed, 18 May 2005 20:18  |  |
| Eclipse User  |  |  |  |  | Originally posted by: jeroen.lightyear.be
 -----BEGIN PGP SIGNED MESSAGE-----
 Hash: SHA1
 Yesterday i played a bit with the bugdel plugin
 (http://www.csg.is.titech.ac.jp/~usui/bugdel/index-e.shtml), which is a
 plugin to debug java app's, by using AOP. By example you can simply
 invoke a System.out.println() whenever a getter or setter is called.
 Since i plan to use Aspects in the feature for other things then just
 debugging i'm wondering if something like bugdel is possible with ajdt
 in a simple way (in bugdel it's allmost only point-and-click, which is
 very sufficient for debugging). I'd rather install only one plugin which
 enables all kinds of AOP in Eclipse then having to use 2 or 3 plugins.
 Another question: I tried AJDT (1.2.0M3 for Eclipse 3.1M6) on Eclipse
 3.1M7 but it doesn't work, is this correct?
 Thx!
 Jeroen
 <TeRanEX/>
 --- e-mail:   jeroen@lightyear.be - jid: teranex@jabber.org
 --- blog: http://budts.be/weblog/ - cv:  http://budts.be/jeroen/
 --- projects: http://lightyear.be - pgp: 0x8B7B774A
 _____________________________________
 NO SoftwarePatents in Europe!
 See an example: http://webshop.ffii.org/
 -----BEGIN PGP SIGNATURE-----
 Version: GnuPG v1.4.1 (MingW32)
 Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
 iD8DBQFCi9toH04wF4t7d0oRAm4uAJ934Zbri336UPF+erV2p3ufhKadTgCe Knrh
 A+7e67IS71RvBYaYKBvZe7E=
 =FIEu
 -----END PGP SIGNATURE-----
| Re: Using AJDT to debug? [message #51834 is a reply to message #51780] | Thu, 19 May 2005 06:04  |  |
| Eclipse User  |  |  |  |  | Originally posted by: mchapman.uk.ibm.com
 I think it's good there is this kind of choice, rather than trying to have
 a single "one size fits all" plugin. Although having an update site for
 bugdel, or a packaging of multiple related plugins would make installation
 easier for end users. That said, I am all for adding value to AJDT where
 it makes sense. We have thought for some time it would be nice to enable
 more uses of AOP via wizards and the like - such as being able to select
 aspects from a library. So feel free to raise an enhancement request for
 some sort of point and click debugging support that could be added to AJDT
 - the more detail the better.
 Yes, unfortunately that is correct. We're working on getting AJDT working
 on Eclipse 3.1M7. We'll release a development build as soon as it's ready.
 Matt.
 Matt Chapman
 AJDT Development, http://www.eclipse.org/ajdt
| Re: Using AJDT to debug? [message #588186 is a reply to message #51780] | Thu, 19 May 2005 06:04  |  |
| Eclipse User  |  |  |  |  | On Thu, 19 May 2005 02:18:49 +0200, Jeroen Budts wrote: > Yesterday i played a bit with the bugdel plugin
 Matt.
 Matt Chapman
FUDForum. Page generated in 0.11707 seconds
