Home » Eclipse Projects » Nebula » Need help to control scrolling in the gallery
Need help to control scrolling in the gallery [message #51775] Tue, 22 April 2008 03:27 Go to next message
I am using a Gallery and am adding (using drag & drop) images into the
gallery but don't seem to be able to stop the gallery repositioning itself
to the top.
I am using SWT.VIRTUAL and gallery.clearAll(); each time I add one or more
items into the middle of the "list";
I have tried: gallery.getVerticalBar().setSelection(scrollPosition);
but that didn't quite work. The scrollbar was set but the gallery was
still positioned at the top.
I also tried gallery.showItem(item); That works pretty well but the shown
Item can be anywhere ( top or bottom) so the page jumps about a bit
unexpectedly for the user.
Any help would be appreciated
Re: Need help to control scrolling in the gallery [message #51994 is a reply to message #51775] Thu, 24 April 2008 04:29 Go to previous message
If you want to use setSelection on a scrollbar, just send a selection
event right after that,
http://sharemedia.svn.sourceforge.net/viewvc/sharemedia/trun k/org.sharemedia.ui.sat/src/org/sharemedia/ui/sat/effects/Mo veScrollBarEffect.java?revision=802&view=markup
But clearAll is not supposed to reset position if Table or Tree does not
do it.
Please fill a bug if the behavior is not the same as Table.
Nicolas
Trevor Campbell a écrit :
> itself to the top.
> more items into the middle of the "list";
> shown Item can be anywhere ( top or bottom) so the page jumps about a
> bit unexpectedly for the user.
> Thanks
Re: Need help to control scrolling in the gallery [message #589462 is a reply to message #51775] Thu, 24 April 2008 04:29 Go to previous message
do it.
Nicolas
> itself to the top.
> Thanks
Previous Topic:Nightly builds?
Next Topic:Disposing of items in the Gallery
Current Time: Tue Nov 04 03:11:36 EST 2025
Powered by FUDForum. Page generated in 0.05243 seconds
