Re: Riena Launch configuration [message #5116 is a reply to message #5046] |
Tue, 17 June 2008 14:36  |
Originally posted by: ekkehard.gentz-software.de
hi christian,
thanks for your answers...
you know I'm new to Riena and so excuse some of my questions -
I only want to know if I understood all right how Riena works
at the same time I'm testing and learning EasyBeans -
and Easybeans per ex. goes another way to start up:
they have an Easybeans agent bundle which itself then starts
all needed components of Easybeans in the correct order
in my current configuration where Riena runs together with
easybeans I do it the recommended ways:
* start all bundles Riena needs
* install all bundles Easybeans needs and start easybeans.agent
* then I start a Riena server
all unit tests run from Riena and all examples run from Easybeans
later this week I'll do 'real' work with this...
....and will report about it of course
ekke
Christian Campo schrieb:
> Is this the way ? Starting all bundles is the only way that you can
> guarantee that all OSGi Services that you need are started. If you dont
> need them Services then you dont need to start all bundles.
> You dont need to run Riena applications as OSGi Framework launcher. You
> can also use Eclipse Application as a typ. Check out the need code that
> we have in CVS (riena.example.client)
> Sorry we still havnt come across to run Riena with Eclipse 3.4.
> christian
> ekke schrieb:
>> christian,
>> looking at your OSGI launch configurations
>> (PingPong Server, Sample App Server)
>> where you start always all bundles
>> is this the recommended way ?
>> or is it possible to install all, but only to start
>> a minimum set of bundles and riena handles
>> starting other bundles if needed ?
>> I'm just configuring some scenarios where Riena
>> runs together with others.... try to figure out
>> different sets of target platform bundles, launch configs etc.
>> I've done the same for 'use of EasyBeans with Equinox 3.4',
>> http://ekkes-corner.blogspot.com/2008/06/easybeans-und-equin ox.html
>> now I'm configuring 'Riena with Equinox 3.4' and then
>> 'Riena + EasyBeans with Equinox 3.4' ...
>> thx for info
>> ekke
>> btw: trying out some target configurations for Riena with
>> Equinox 3.4 I run into some problems with Target Platforms
>> from different locations with different versions of the same plugin
>> http://ekkes-corner.blogspot.com/2008/06/pde-target-platform -from-different.html)
>> perhaps someone else needs this functionality and votes for
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=233095 and
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=233096 - thx
Re: Riena Launch configuration [message #572144 is a reply to message #4559] |
Tue, 17 June 2008 14:27  |
Is this the way ? Starting all bundles is the only way that you can guarantee that all OSGi Services that you need are
started. If you dont need them Services then you dont need to start all bundles.
You dont need to run Riena applications as OSGi Framework launcher. You can also use Eclipse Application as a typ. Check
out the need code that we have in CVS (riena.example.client)
christian
ekke schrieb:
> christian,
> thx for info
> ekke
Re: Riena Launch configuration [message #572175 is a reply to message #5046] |
hi christian,
ekke
> christian
> ekke schrieb:
>> christian,
>> thx for info
>> ekke
FUDForum. Page generated in 0.04593 seconds
