Home » Modeling » GMF (Graphical Modeling Framework) » Adding one more column in the property veiw
Adding one more column in the property veiw [message #51759] Wed, 20 September 2006 06:33 Go to next message
Originally posted by: vikas.goyal.hp.com
I am trying to add one more column in the property veiw. In gmf from
diagram file if we select any element and try to see its property view we
can see two column over there which are property and value. I am trying to
add one more column say customizable in this view.
Can some one help me which file creates the property table and how can I
add one more column over there.
Thanks in Advance.
Vikas Goyal
Re: Adding one more column in the property veiw [message #51859 is a reply to message #51759] Wed, 20 September 2006 07:06 Go to previous message
Adding another column to standard property view is a general task and is not
GMF-specific. Take a look at
org.eclipse.ui.views.properties.PropertySheetPage and
org.eclipse.ui.views.properties.PropertySheetViewer classes (latter has tree
field with columns you would like to augment).
The way to get your modified viewer into GMF depends on whether you use GMF
1.0 or latest milestones.
Artem
"Vikas Goyal" <vikas.goyal@hp.com> wrote in message
news:c03bca7edd1fd9c7a0227ea565877dea$1@www.eclipse.org...
> Hi, I am trying to add one more column in the property veiw. In gmf from
> Thanks in Advance.
> Regards
> Vikas Goyal
Previous Topic:Multiple links in mindmap example
Next Topic:Cannot run Taipan
Current Time: Fri Nov 21 04:51:54 EST 2025
Powered by FUDForum. Page generated in 0.07815 seconds
