Home » General (non-technical) » Eclipse Foundation » Re: Number of reported bugs - Eclipse versions
Re: Number of reported bugs - Eclipse versions [message #51702] Tue, 12 February 2008 13:59
Originally posted by: wharley.bea.com
"Martin" <weiglhofer@ist.tugraz.at> wrote in message
news:fos8l4$hce$1@build.eclipse.org...
> Walter Harley wrote:
>> Bugs have whatever version they were reported against. That's not an
>> automated feature, it just depends on the person reporting the bug. If
>> you
>> report a bug, you say what version you're reporting it on. Probably a
>> lot
>> of the time, people misreport, e.g. they report "3.2" when really they're
>> using 3.2.2.
> Thanks for clarifying this. If I understood that explanation correctly
> this implies for me, that reports generated by bugs.eclipse.org may be
> misinterpreted.
> For example, consider the report [1] which shows the number of
> open/unconfirmed/assigned bugs for every Eclipse version. Using the
> above explanation, this means for me, that this graph should be a
> stair-case like function instead of having a saw tooth like shape.
> Am I right?
No, because when a bug is closed, it is no longer open/unconfirmed/assigned.
You'd only see a staircase if bugs were never closed. Hopefully we're a
little better than that :-)
But it is true that any report will be just an approximation. Everything to
do with bugs - even whether something is or is not a bug - represents a
judgement call by human beings.
Previous Topic:Voting is Open for the Individual Eclipse Community Awards
Next Topic:Re: Number of reported bugs - Eclipse versions
Current Time: Sat Nov 08 11:40:19 EST 2025
Powered by FUDForum. Page generated in 0.03172 seconds
