Home » Archived » EPF » Re-use RichTextEditor in a non-EPF plugin
Re-use RichTextEditor in a non-EPF plugin [message #51635] Fri, 27 June 2008 03:33 Go to next message
I'm trying to re-use RichTextEditor in a non EPF plugin.
I'm using Eclipse 3.4RC4, Ubuntu 8.04 - Hardy Heron, Firefox 3.0 and
XulRunner 1.9.
I have a RichTextEditor and a button to validate.
I'm having problems with the recovery of the text. When i call the
getText() method it returns me the state -1 instead
of the current state. It returns me the old value of the text.
If I press the button 2 time it returns me the good text.
When I use Html view all works correctly
Has someone encountered the same problem?
Re: Re-use RichTextEditor in a non-EPF plugin [message #51655 is a reply to message #51635] Fri, 27 June 2008 13:11 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Are you using RTE feature which was published in EPF 1.2.0.4 ?
Is EPF - RTE works fine on your specified system ? If no, then it could be
RTE bug. File a bug in that case.
Shilpa
Re: Re-use RichTextEditor in a non-EPF plugin [message #51719 is a reply to message #51655] Mon, 30 June 2008 03:36 Go to previous messageGo to next message
Yes I'm using EPF Richtext Feature 1.2.0.4.
EPF - RTE have the same bug. I will file the bug...
Re: Re-use RichTextEditor in a non-EPF plugin [message #51751 is a reply to message #51719] Mon, 30 June 2008 06:16 Go to previous message
Here is the link to the associated bug :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238939
Re: Re-use RichTextEditor in a non-EPF plugin [message #589762 is a reply to message #51635] Fri, 27 June 2008 13:11 Go to previous message
Shilpa
Re: Re-use RichTextEditor in a non-EPF plugin [message #589785 is a reply to message #51655] Mon, 30 June 2008 03:36 Go to previous message
Re: Re-use RichTextEditor in a non-EPF plugin [message #589795 is a reply to message #51719] Mon, 30 June 2008 06:16 Go to previous message
Previous Topic:Can't update EPF
Next Topic:Generating EPF XML Import file from external content
Current Time: Fri Nov 07 11:42:10 EST 2025
Powered by FUDForum. Page generated in 0.04662 seconds
