| [ATL]: Installation from source [message #51627] |
Mon, 09 July 2007 07:50   |
Eclipse User  |
Hi All,
I tried to install ATL and AM3 from source. I followed the instructions
on the Wiki. The problems described below occur when I export the
adt/am3 plugins and subsequently install them (i.e., not when running a
second workbench from eclipse).
When I open the ATL editor I get the first exception below and the
navigator does not show up. When opening the AM3 perpective I get the
second exception below and the resource navigotor does not show up.
Does anybody know a solution to this problem?
Kind regards,
Bas.
when I open the ATL editor I get:
java.lang.NoClassDefFoundError:
org/eclipse/m2m/atl/engine/injectors/Injector
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
 org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
 org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
	at  java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
 org.eclipse.m2m.atl.adt.ui.outline.AtlContentOutlinePage.set Unit(AtlContentOutlinePage.java:438)
 org.eclipse.m2m.atl.adt.ui.outline.AtlContentOutlinePage.cre ateControl(AtlContentOutlinePage.java:321)
 org.eclipse.ui.views.contentoutline.ContentOutline.doCreateP age(ContentOutline.java:134)
	at  org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:399)
	at  org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:743)
	at  org.eclipse.ui.internal.PartListenerList$1.run(PartListenerL ist.java:72)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
	at org.eclipse.core.runtime.Platform.run(Platform.java:843)
 org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:57)
 org.eclipse.ui.internal.PartListenerList.firePartActivated(P artListenerList.java:70)
 org.eclipse.ui.internal.PartService.firePartActivated(PartSe rvice.java:73)
	at  org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:171)
 org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:56)
	at  org.eclipse.ui.internal.PartList.setActivePart(PartList.java :126)
 org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3207)
	at  org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:588)
 org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2604)
 org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
	at  org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
	at  org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
	at  org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
 org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
 org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2485)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:388)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:350)
	at  org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
 org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
 org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:125)
 org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:328)
 org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:679)
 org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:434)
 org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:817)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
	at  org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
 org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:815)
 org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1069)
 org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1168)
	at  org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:249)
	at  org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:243)
	at  org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:283)
	at  org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
	at  org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3166)
	at  org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2842)
	at  org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
	at  org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
 org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
	at  org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
	at  org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
 org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
	at  org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
	at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
	at org.eclipse.core.launcher.Main.run(Main.java:977)
	at org.eclipse.core.launcher.Main.main(Main.java:952)
when opening the AM3 perspective I get:
org/eclipse/m2m/atl/engine/vm/nativelib/ASMOclAny
	at java.lang.Class.getDeclaredConstructors0(Native Method)
	at  java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
	at java.lang.Class.getConstructor0(Class.java:2699)
	at java.lang.Class.newInstance0(Class.java:326)
	at java.lang.Class.newInstance(Class.java:308)
 org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
 org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
 org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
 org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
 org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:234)
 org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.java:69)
 org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:292)
	at  org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
 org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
	at  org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 0)
	at  org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 5)
 org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:140)
 org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
 org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
 org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:394)
 org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1144)
	at  org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1097)
	at  org.eclipse.ui.internal.PartStack.showPart(PartStack.java:13 11)
	at  org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:601)
	at  org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:532)
 org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:562)
 org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:244)
	at  org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:815)
 org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:3284)
 org.eclipse.ui.internal.WorkbenchPage.busyResetPerspective(W orkbenchPage.java:893)
	at  org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:829)
	at  org.eclipse.ui.internal.WorkbenchPage$11.run(WorkbenchPage.j ava:2766)
 org.eclipse.ui.internal.WorkbenchPage.resetPerspective(Workb enchPage.java:2764)
 org.eclipse.ui.internal.ResetPerspectiveAction.run(ResetPers pectiveAction.java:58)
	at  org.eclipse.ui.internal.PerspectiveAction.run(PerspectiveAct ion.java:70)
	at  org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
 org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
 org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
 org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
| Re: [ATL]: Installation from source [message #52201 is a reply to message #51884] |
Thu, 12 July 2007 07:38   |
Eclipse User  |
Hi Frederic,
That plugin is in fact installed. I tried the following with a new
installation of Eclipse (3.2.1) and EMF (2.2.3):
- Import required ATL and AM3 plugin projects from CVS
- Add antlr.jar and mdr-jars
- Compile
- Start (secondary) Eclipse instance
--> AM3 and ATL work as they should
- Export set of imported projects as plugins
- Extract in plugin directory
- Restart Eclipse (-clean)
--> switching to AM3 perspective, and opening ATL editor gives the
exceptions below
Kind regards,
Bas.
Frédéric Jouault wrote:
> Hi Bas,
> It seems that classes from the org.eclipse.m2m.atl.engine.vm plugin are
> not found. Can you please make sure that this plugin is installed?
> Frédéric Jouault
> Bas Graaf wrote:
>> Hi All,
>> instructions on the Wiki. The problems described below occur when I
>> export the adt/am3 plugins and subsequently install them (i.e., not
>> when running a second workbench from eclipse).
>> Thanks,
>> Kind regards,
>> Bas.
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>     at
>>     at
>>     at java.lang.reflect.Method.invoke(Method.java:597)
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
>>     at
FUDForum. Page generated in 0.06422 seconds
