Home » Archived » EPF » Automatically expanding node tree when opening workflow/task description
Automatically expanding node tree when opening workflow/task description [message #51549] Tue, 24 June 2008 14:19 Go to next message
Originally posted by: jhnewsgroup1.nebo-consulting.de
Hi!
In contrast to other sides the navigator tree in a published web site is not
in sync if I open a workflow page or after selecting a task description.
This means the auto expand and auto selection behavior doesn't work.
Is there a possibilty (by code-customizing) to change this behavior? I've
already tried to adapt the common known .js scripts by setting the global
values or setting the hastree parameter. May be an automatic call of whoamI
function would be a solution?
Thank you for your answers
Best regards
Juergen
Re: Automatically expanding node tree when opening workflow/task description [message #51616 is a reply to message #51549] Thu, 26 June 2008 18:00 Go to previous message
Originally posted by: Jorge.xxx.xxx
This functionality seems to be available in RMC rational method composer,
which is built on top of EPF. They also have nice look & feel of tree
browser for published site.
Jorge.
Re: Automatically expanding node tree when opening workflow/task description [message #589743 is a reply to message #51549] Thu, 26 June 2008 18:00 Go to previous message
Jorge.
Previous Topic:Plan for 1.2.0.4 release?
Next Topic:Re-use RichTextEditor in a non-EPF plugin
Current Time: Fri Jul 18 04:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.24332 seconds
