Home » Eclipse Projects » Technology Project and PMC » unable to find javac compiler
unable to find javac compiler [message #51548] Fri, 04 April 2003 07:42 Go to next message
Originally posted by: mikeamickey.web.de
Hi everybody.
When running ant tasks I get the following message.
[javac] BUILD FAILED: file:D:/Sun ONE
Projects/noah/NoahJava/build.xml:235: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
I added JAVA_HOME in Preferences->Java->Classpath Variables with the JDK
root folder but it still does not work.
Michael
Re: unable to find javac compiler [message #51574 is a reply to message #51548] Fri, 04 April 2003 08:55 Go to previous messageGo to next message
You should try to add tools.jar in runtime settings for ant.
regards,
stoil
"Michael Hartmann" <mikeamickey@web.de> wrote in message
news:b6juio$1oh$1@rogue.oti.com...
> Hi everybody.
> Michael
Re: unable to find javac compiler [message #51596 is a reply to message #51574] Fri, 04 April 2003 12:00 Go to previous message
Or you can start eclipse with your JDK install using the -vm arg...then
tools.jar will be added automatically.
Darins
"Stoil Valchkov" <ssv_1234@hotmail.com> wrote in message
news:b6k2h3$6e3$1@rogue.oti.com...
> regards,
> stoil
> > Hi everybody.
> > Thanks,
> > Michael
Re: unable to find javac compiler [message #592520 is a reply to message #51548] Fri, 04 April 2003 08:55 Go to previous message
regards,
stoil
> Hi everybody.
> Michael
Re: unable to find javac compiler [message #592529 is a reply to message #51574] Fri, 04 April 2003 12:00 Go to previous message
Darins
> regards,
> stoil
> > Hi everybody.
> > Thanks,
> > Michael
Previous Topic:exception on start up eclipse
Next Topic:Can I create build.xml file of ANT with Eclipse?
Current Time: Thu Nov 06 01:16:44 EST 2025
Powered by FUDForum. Page generated in 0.05352 seconds
