Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Re: How impl "xsd:choice" model constraint ?
Re: How impl "xsd:choice" model constraint ? [message #51514] Thu, 21 September 2006 09:24 Go to next message
--------------020305030703090704000500
Radek,
No, EMF doesn't currently validate "complex" particle constraints. It's
our oldest feature request to do that and I have prototyped an approach
for doing so:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210>
I'm pretty sure OCL could be used to express mutual exclusion type of
constraint. I've asked Christian to have a look at this question and
added the EMFT newsgroup, which is a better place to ask about OCL...
Radek Dvorak wrote:
> Hi tiggo,
> GMF does not process <xsd:choice> at all.
> Please, check if EMF is able to use xsd:choice elements in EMF validation
> mechanism.
> If yes, GMF validation involves EMF validators automatically and visualizes
> the resulting diagnostics (if validation enabled).
> As for expressing it in OCL, in principal you can do it (manually ;)). It
> just depends on how complex the constraint is and
> whether OCL is straightforward tool for this.
> /Radek
> "tiggo" <tiggo.kan@gmail.com> wrote in message
> news:ees0uk$vf9$1@utils.eclipse.org...
>> Hello,
>> As illustrated in a tutorial, a simple ocl-based constraint can be
>> supported in gmfmap model, But I know little about OCL... Just wonder
>> whether "<xsd:choice>" constraint can be expressed by OCL? If can, GMF
>> also can generate such codes?
>> In my semantic model, "<xsd:choice>" is used on a container, which has
>> such restriction on children.
>> thanks for any suggestion.
>> regards / tiggo
<html>
<head>
</head>
Radek,<br>
<br>
No, EMF doesn't currently validate "complex" particle constraints.&nbsp;
It's our oldest feature request to do that and I have prototyped an
approach for doing so:<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210">https://bugs.eclipse.org/bugs/show_bug.cgi?id=51210</a><br>
</blockquote>
constraint.&nbsp; I've asked Christian to have a look at this question and
added the EMFT newsgroup, which is a better place to ask about OCL...<br>
<br>
<br>
Radek Dvorak wrote:
<blockquote cite="mideeu186$gli$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi tiggo,
GMF does not process &lt;xsd:choice&gt; at all.
mechanism.
/Radek
"tiggo" <a class="moz-txt-link-rfc2396E" href="mailto:tiggo.kan@gmail.com">&lt;tiggo.kan@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:ees0uk$vf9$1@utils.eclipse.org">news:ees0uk$vf9$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hello,
whether "&lt;xsd:choice&gt;" constraint can be expressed by OCL? If can, GMF
In my semantic model, "&lt;xsd:choice&gt;" is used on a container, which has
regards / tiggo
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020305030703090704000500--
Re: How impl "xsd:choice" model constraint ? [message #51540 is a reply to message #51514] Thu, 21 September 2006 10:12 Go to previous message
Hi, all,
See my reply to the other branch of this thread in the GMF newsgroup (sorry,
should have cross-posted my reply).
Christian
Ed Merks wrote:
> Radek,
> for doing so:
> Radek Dvorak wrote:
>> Hi tiggo,
>> mechanism.
>> visualizes the resulting diagnostics (if validation enabled).
>> Regards,
>> /Radek
>>> Hello,
>>> regards / tiggo
Re: How impl "xsd:choice" model constraint ? [message #591597 is a reply to message #51514] Thu, 21 September 2006 10:12 Go to previous message
Hi, all,
Christian
Ed Merks wrote:
> Radek,
> for doing so:
> Radek Dvorak wrote:
>> Hi tiggo,
>> mechanism.
>> Regards,
>> /Radek
>>> Hello,
>>> regards / tiggo
Previous Topic:Re: How impl "xsd:choice" model constraint ?
Next Topic:java.lang.ClassCircularityError with Teneo
Current Time: Wed Nov 05 12:09:09 EST 2025
Powered by FUDForum. Page generated in 0.03818 seconds
