Home » Eclipse Projects » GEF » adding connections to the TreeViewer
adding connections to the TreeViewer [message #51504] Sat, 28 December 2002 17:22 Go to next message
Originally posted by: assisi2000.yahoo.com
How can I add connection parts to the TreeViewer like all the other parts
in the logic example?
Re: adding connections to the TreeViewer [message #51599 is a reply to message #51504] Mon, 30 December 2002 09:47 Go to previous message
Originally posted by: hudsonr.us.eye-bee-em.com
It should be possible, but it is unlikely that you render the terminals in
the tree. Therefore, you might need to popup a menu on each "node" to have
the user select the appropriate source and target ports.
"Ramin" <assisi2000@yahoo.com> wrote in message
news:aul87n$1cb$1@rogue.oti.com...
Previous Topic:Connection / Shape tool accessibility
Next Topic:Need help: Problem with Deployment
Current Time: Fri Nov 28 09:22:36 EST 2025
Powered by FUDForum. Page generated in 0.04239 seconds
