Home » Eclipse Projects » Nebula » Preserving cell selection and focus in GridTableViewer
Preserving cell selection and focus in GridTableViewer [message #51485] Sat, 12 April 2008 18:58 Go to next message
Hi there,
It may seem to be a lower priority to some of you, but I could not stand
the cell selection and focus get messed up after for example sorting the
grid.
Don't you think it'd be good to have in the official implementation?
Anyway I attach a quick work around I currently employ. May be someone
would like to use it as it is for the time being or include it into main
branch eventually.
Cheers
Jacek
final GridTableViewer v = new GridTableViewer(grid) {
* Represents the cell in the model terms.
* Translates back and forth between model cell and
* current grid coordinates where it's prsented.
class ModelCell {
Object element;
String property;
public ModelCell(Point p) {
property = getColumnProperties()[p.x].toString();
element = getElementAt(p.y);
public Point getPoint() {
return new Point(
Arrays.asList(getColumnProperties()).indexOf(property),
grid.indexOf((GridItem) findItem(element)));
protected void preservingSelection(Runnable updateCode) {
if (!getGrid().getCellSelectionEnabled()) {
super.preservingSelection(updateCode);
return;
ArrayList<ModelCell> oldCellSelection = new ArrayList<ModelCell>();
ModelCell oldFocus = null;
boolean restoreSelection = true;
try {
// preserve cell selection
for (Point p: getGrid().getCellSelection()) {
oldCellSelection.add(new ModelCell(p));
// preserve cell focus
if (grid.getFocusItem() != null)
oldFocus = new ModelCell(grid.getFocusCell());
// perform the update
} finally {
// restore selection
if (restoreSelection) {
grid.deselectAll();
// set cell selection
for (ModelCell sel: oldCellSelection) {
grid.selectCell(sel.getPoint());
// set focus
if (oldFocus != null) {
Point p = oldFocus.getPoint();
grid.setFocusItem(grid.getItem(p.y));
grid.setFocusColumn(grid.getColumn(p.x));
Re: Preserving cell selection and focus in GridTableViewer [message #51515 is a reply to message #51485] Mon, 14 April 2008 07:58 Go to previous messageGo to next message
Did you filed a bug report for this?
Tom
Jacek Kolodziejczyk schrieb:
> Hi there,
> grid.
> branch eventually.
> Cheers
> Jacek
> class ModelCell {
> Object element;
> String property;
> return new Point(
> @Override
> return;
> try {
> } finally {
> grid.deselectAll();
> // set focus
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Preserving cell selection and focus in GridTableViewer [message #51541 is a reply to message #51515] Mon, 14 April 2008 10:27 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226936
J.
> Tom
>> Hi there,
>> stand the cell selection and focus get messed up after for example
>> sorting the grid.
>> main branch eventually.
>> Cheers
>> Jacek
>> class ModelCell {
>> Object element;
>> String property;
>> return new Point(
>> @Override
>> return;
>> try {
>> } finally {
>> grid.deselectAll();
>> // set focus
Re: Preserving cell selection and focus in GridTableViewer [message #52449 is a reply to message #51485] Fri, 09 May 2008 14:36 Go to previous message
My previous snippet did not consider some edge conditions like no items,
column removal or item removal. Below is an improved version.
Cheers
Jacek
* Assumption: model property must identified by a String value in
the column.getData("property").
* This removes dependency on deprecated
viewer.getColumnProperties() method.
return;
ModelCell oldFocusModel = null;
Point oldFocusCell = null;
try {
if (getGrid().getFocusItem() != null &&
getGrid().getFocusColumn() != null) {
oldFocusCell = getGrid().getFocusCell();
oldFocusModel = new ModelCell(oldFocusCell);
} finally {
getGrid().deselectAll();
Point p = sel.getPoint();
if (p != null)
getGrid().selectCell(p);
// set focus
if (oldFocusCell != null && getGrid().getItemCount() > 0) {
Point p = null;
if (oldFocusModel != null) p =
oldFocusModel.getPoint();
if (p == null) {
// It means old focus element property has been
removed
oldFocusCell.y = Math.min(oldFocusCell.y,
getGrid().getItemCount()-1);
oldFocusCell.x = Math.min(oldFocusCell.x,
getGrid().getColumnCount()-1);
p = oldFocusCell;
p.y = Math.max(p.y, 0);
p.x = Math.max(p.x, 0);
getGrid().setFocusItem(getGrid().getItem(p.y));
getGrid().setFocusColumn(getGrid().getColumn(p.x));
* Translates back and forth between model cell and current
getGrid() coordinates.
class ModelCell {
Object element;
String property;
property =
getGrid().getColumn(p.x).getData("property").toString();
GridItem item = (GridItem) findItem(element);
int columnIndex = -1;
for (GridColumn column: getGrid().getColumns())
if (column.getData("property").equals(property)) {
columnIndex = getGrid().indexOf(column);
break;
if (item == null || columnIndex == -1) return null;
return new Point(columnIndex, getGrid().indexOf(item));
Re: Preserving cell selection and focus in GridTableViewer [message #589257 is a reply to message #51485] Mon, 14 April 2008 07:58 Go to previous message
Tom
> Hi there,
> grid.
> branch eventually.
> Cheers
> Jacek
> class ModelCell {
> Object element;
> String property;
> return new Point(
> @Override
> return;
> try {
> } finally {
> grid.deselectAll();
> // set focus
Re: Preserving cell selection and focus in GridTableViewer [message #589270 is a reply to message #51515] Mon, 14 April 2008 10:27 Go to previous message
J.
> Tom
>> Hi there,
>> sorting the grid.
>> Cheers
>> Jacek
>> class ModelCell {
>> Object element;
>> String property;
>> return new Point(
>> @Override
>> return;
>> try {
>> } finally {
>> grid.deselectAll();
>> // set focus
Re: Preserving cell selection and focus in GridTableViewer [message #589630 is a reply to message #51485] Fri, 09 May 2008 14:36 Go to previous message
Cheers
Jacek
return;
try {
} finally {
if (p != null)
// set focus
Point p = null;
if (p == null) {
removed
p = oldFocusCell;
class ModelCell {
Object element;
String property;
property =
break;
Previous Topic:Calender with highlighted dates
Next Topic:Grid SetColumnOrder
Current Time: Wed Nov 19 03:27:49 EST 2025
Powered by FUDForum. Page generated in 0.04725 seconds
