| Help - Installation problems [message #51471] |
Tue, 02 November 2004 15:13  |
Originally posted by: jeffmil.us.ibm.com
Folks, I've downloaded and unzipped both wtp-1.0M1.zip and
wtp-wst-1.0M1.zip and restarted Eclipse. I see nothing relate to Web
tools anywhere in the application. Is there something else I have to do
in the install?
Thanks alot,
<WS-Jeff>
jeffmil@us.ibm.com
| Re: Help - Installation problems [message #51546 is a reply to message #51498] |
Wed, 03 November 2004 08:08   |
Chemi, that was it. I had looked there before and didn't see anything
related. But then I saw I had to show the disabled features and then I
could see the WTP stuff. And after enabling it I could see the
functionality in Eclipse. I have a few duplicate Preferences entries
around Servers and Web but I will clear that one up later. Thanks for
your help!
</WS-Jeff>
Chemi wrote:
> First of all, you just need wtp-1.0M1.zip (which includes
> wtp-wst-1.0M1.zip).
> Once you have installed that file, start Eclipse R3.0.1, go to: Help ->
> Software Updates -> Manage Configuration... and make sure that the
> feature is enabled.
> Then, go to File -> New -> Other and make sure you have two folders
> called: J2EE and Servers.
> Please, notice that WTP M1 hasn't the functuonality needed to work on
> J2EE projects.... so you won't see a JSP editor o a EJB wizard yet. But
> things are moving.....
> Chemi.
>> do in the install?
>> Thanks alot,
>> <WS-Jeff>
>> jeffmil@us.ibm.com
| Re: Help - Installation problems [message #52297 is a reply to message #51546] |
Mon, 08 November 2004 09:49   |
> your help!
> </WS-Jeff>
>> wtp-wst-1.0M1.zip).
>> feature is enabled.
>> Regards,
>> Chemi.
>>> do in the install?
>>> Thanks alot,
>>> <WS-Jeff>
>>> jeffmil@us.ibm.com
Very thanks your help,Chemi.I'm just forgotten that eclipse sometimes should
disable new features installed.
Thanks again.
Hello,friend from world of eclipse.I am a new-bie in the world of java and
eclipse.I need your help to improve my ability and make the java world
better and stronger.
| Re: Webtools and OC4J ... nearly?! solved [message #65994 is a reply to message #65939] |
Tue, 18 January 2005 12:06  |
Hi again,
and sorry for the double posting...
now I got the OC4J to display in the List... I also get Errors on start
ing when an other instance is already running on the same port and
stuff... but I can't get the thing to keep up after it started it
immediatly shuts down... anyone got the webtools running with oc4j?!?!
thnx
FUDForum. Page generated in 0.06216 seconds
