Home » Language IDEs » ServerTools (WTP) » FAQ
FAQ [message #51386] Sat, 30 October 2004 17:58 Go to next message
Web Toolers,
We now have a minimal FAQ on the website
(http://www.eclipse.org/webtools/faq/main.html). We have also created a
Bugzilla component named "FAQ" (https://bugs.eclipse.org/bugs/). When you
come across something that you think should be in the FAQ, either a question
or an answer, just open a bug report for component FAQ. That will trigger
the committers and contributors to post the question and answer to the FAQ
list.
- Bjorn
Re: FAQ [message #55716 is a reply to message #51386] Thu, 09 December 2004 15:46 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
Bjorn Freeman-Benson wrote:
> Web Toolers,
> list.
Just not to pollute FAQ: is/will be DTD/Schema based XML editor
available as a lightweight plugin outside WTP?
10x,
Sam Mesh
Re: FAQ [message #60213 is a reply to message #55716] Tue, 04 January 2005 13:35 Go to previous messageGo to next message
Hi Sam,
The XML editor builds on top of the structured source editor (SSE) which
has other WTP dependencies. To only use the XML editor from the WTP
project you will need (I think I got all the dependencies)
org.eclipse.wst.xml.ui plugin
org.eclipse.wst.xml.core
org.eclipse.wst.xml.uriresolver
org.eclipse.wst.xml.uriresolver.ui
org.eclipse.wst.sse.ui
org.eclipse.wst.sse.core
org.eclipse.wst.dtd.ui
org.eclipse.wst.dtd.core
org.eclipse.wst.common.contentmodel
org.eclipse.wst.common.encoding
org.eclipse.wst.common.uriresolver
org.eclipse.wst.common.ui
org.eclipse.wst.common.frameworks
org.eclipse.wst.validation
I believe there was also some talk of creating separate downloads from the
WTP downloads page such as for XML editing (which would probably contain
the DTD, XSD, and XML editors and validators and their prereqs). If this
is of interest to the community it is something that can be discussed.
Lawrence
Re: FAQ [message #60894 is a reply to message #60213] Tue, 04 January 2005 21:23 Go to previous message
Originally posted by: rgardler.come_now_no_spam-apache.org
Lawrence Mandel wrote:
> Hi Sam,
For reference, this would certainly be of interest for us.
Ross
Previous Topic:JSP 'Open Declaration' option in M2
Next Topic:serializable class and serialVersionUID
Current Time: Sat Nov 22 02:41:37 EST 2025
Powered by FUDForum. Page generated in 0.05314 seconds
