Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo : Problem with Library Editor Tutorial
Teneo : Problem with Library Editor Tutorial [message #51378] Thu, 21 September 2006 04:36 Go to next message
Originally posted by: nrobin.irisa.fr
Hi Martin,
We wanted to switch our application, that was working fine with Elver
Store, to Teneo. We experienced problems ("NoClassDefFound" errors
loading Dom4J classes) so we decided to return to the Library Editor
Tutorial. And it doesn't seem to work with us. The EMF part of the
tutorial is working fine but when we add the Teneo code, we're having
this error message :
"Problem Opening Wizard"
"The selected wizard could not be started.
Reason:
Plug-in library.editor was unable to load class
org.eclipse.example.library.presentation.LibraryModelWizard"
And here is the stack trace we got from catching the exception :
"org.hibernate.MappingException: Could not determine type for:
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType,
for columns: [org.hibernate.mapping.Column(econtainer_class),
org.hibernate.mapping.Column(e_container)]
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 66)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 53)
at org.hibernate.mapping.Property.isValid(Property.java:185)
org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:399)
at org.hibernate.mapping.RootClass.validate(RootClass.java:192)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 1026)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1211)
org.eclipse.emf.teneo.hibernate.HbDataStore.buildSessionFact ory(HbDataStore.java:474)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:187)
org.eclipse.example.library.presentation.LibraryEditorPlugin $Implementation.start(LibraryEditorPlugin.java:119)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:238)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExtension(WorkbenchWizardElement.java:117)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eWizard(WorkbenchWizardElement.java:261)
org.eclipse.ui.internal.dialogs.NewWizardNewPage$6.createWiz ard(NewWizardNewPage.java:766)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNode.java:148)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNode.java:131)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizardNode.java:128)
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:104)
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:100)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:751)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:351)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)"
We're using the Teneo version from the update site (0.7.5) and we
created a separated Hibernate plug-in with version 3.2.0 cr3.
We also have Eclipse 3.2.0, EMF 2.2.0 and a JDK 1.5.0_04.
Thanks for your help,
Nicolas ROBIN & Benoît LAMARCHE
Re: Teneo : Problem with Library Editor Tutorial [message #51588 is a reply to message #51378] Thu, 21 September 2006 10:51 Go to previous messageGo to next message
Hi Nicolas,
My guess is that this is related to dependencies which are not resolved. In the hibernate plugin did
you export all (is the savest) hibernate java packages?
Did you check the reexport property of the dependency of the hibernate plugin in the model plugin?
gr. Martin
Nicolas Robin wrote:
> Hi Martin,
> Reason:
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo : Problem with Library Editor Tutorial [message #51818 is a reply to message #51588] Fri, 22 September 2006 04:43 Go to previous messageGo to next message
Hi Martin,
Thanks for your answer. We've restarted the Library Editor Tutorial from
scratch, in a new workspace and created a new Hibernate plug-in. We're
having the same error but a different stack trace.
In our Hibernate plug-in, we've added the hibernate3.jar and all the
jars that were in the "lib" directory, and we've exported each of them.
The reexport properties of the Hibernate and Teneo plug-ins dependencies
in the model plug-in are set. The "org/hibernate/mapping/Value" class
does exist in the hibernate jar. I don't understand what we did wrong.
Here is the new stack trace :
"java.lang.NoClassDefFoundError: org/hibernate/mapping/Value
org.eclipse.emf.teneo.hibernate.HbHelper$1.createHbDataStore (HbHelper.java:56)
org.eclipse.emf.teneo.hibernate.HbHelper.createRegisterDataS tore(HbHelper.java:150)
org.eclipse.example.library.presentation.LibraryEditorPlugin $Implementation.start(LibraryEditorPlugin.java:117)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advan ceToNextPageOrFinish(NewWizardSelectionPage.java:71)
org.eclipse.ui.internal.dialogs.NewWizardNewPage$1.doubleCli ck(NewWizardNewPage.java:364)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:796)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:794)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1216)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1158)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:223)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:220)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:281)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
Thanks for your time
Martin Taal wrote :
> Hi Nicolas,
> In the hibernate plugin did you export all (is the savest) hibernate
> java packages?
> gr. Martin
>> Hi Martin,
>> Reason:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
Re: Teneo : Problem with Library Editor Tutorial [message #51871 is a reply to message #51818] Fri, 22 September 2006 07:14 Go to previous messageGo to next message
Hi Nicolas,
When you add the import statement:
import org.hibernate.mapping.Value;
to the class: org.eclipse.example.library.presentation.LibraryEditorPlugin .
Does the compiler complain?
If the compiler complains, can you then check if the hibernate packages are exported in the runtime
tab of the hibernate plugin Manifest.MF?
Also the hibernate plugin must have this in the manifest.mf:
Eclipse-BuddyPolicy: dependent
Another eclipse-buddypolicy can work also. Although this is not related to this issue.
gr. Martin
> Hi Martin,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote :
>> Hi Nicolas,
>> resolved. In the hibernate plugin did you export all (is the savest)
>> gr. Martin
>>> Hi Martin,
>>> Reason:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #51899 is a reply to message #51871] Fri, 22 September 2006 07:51 Go to previous messageGo to next message
When we add the import statement, there's no error. We had forgotten to
put the "Eclipse-BuddyPolicy: dependent" but it didn't change anything.
We still have the same error and stack trace.
Thanks for trying to help
Martin Taal wrote :
> Hi Nicolas,
> are exported in the runtime tab of the hibernate plugin Manifest.MF?
> to this issue.
> gr. Martin
>> Hi Martin,
>> from scratch, in a new workspace and created a new Hibernate plug-in.
>> We're having the same error but a different stack trace.
>> them. The reexport properties of the Hibernate and Teneo plug-ins
>> dependencies in the model plug-in are set. The
>> "org/hibernate/mapping/Value" class does exist in the hibernate jar. I
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> gr. Martin
>>>> Hi Martin,
>>>> Elver Store, to Teneo. We experienced problems ("NoClassDefFound"
>>>> errors loading Dom4J classes) so we decided to return to the Library
>>>> Editor Tutorial. And it doesn't seem to work with us. The EMF part
>>>> of the tutorial is working fine but when we add the Teneo code,
>>>> we're having this error message :
>>>> Reason:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #51928 is a reply to message #51899] Fri, 22 September 2006 08:07 Go to previous messageGo to next message
Hi Nicolas,
Okay, can you upload a screendump of the jars in your hibernate plugin as eclipse display it?
Can you comment out the teneo part in the editorplugin and just try some basic hibernate stuff such
as create a configuration and a SessionFactory? To see if that also fails.
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> to the class:
>> packages are exported in the runtime tab of the hibernate plugin
>> Manifest.MF?
>> gr. Martin
>>> Hi Martin,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> Library Editor Tutorial. And it doesn't seem to work with us. The
>>>>> EMF part of the tutorial is working fine but when we add the Teneo
>>>>> code, we're having this error message :
>>>>> Reason:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #52115 is a reply to message #51928] Fri, 22 September 2006 09:44 Go to previous messageGo to next message
We've tried to comment out all the teneo part and we only left this line
in the start() function : "Configuration cfg = new Configuration();". It
failed. I guess there's really a problem with our Hibernate plug-in.
Here is the screen dump (I hope this is what you wanted) :
http://www.onetwothreefour.info/screendump.gif
Martin Taal wrote :
> Hi Nicolas,
> basic hibernate stuff such as create a configuration and a
> gr. Martin
>> to put the "Eclipse-BuddyPolicy: dependent" but it didn't change
>> anything.
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> to the class:
>>> Manifest.MF?
>>> gr. Martin
>>>> Hi Martin,
>>>> plug-in. We're having the same error but a different stack trace.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Martin Taal wrote :
>>>>> Hi Nicolas,
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> Reason:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #52168 is a reply to message #52115] Fri, 22 September 2006 10:00 Go to previous messageGo to next message
Hi Nicolas,
You can also try the following: add the hibernate plugin directly to the edit plugin dependency (and
remove it from the model).
Or copy all the hibernate jars to the edit plugin and add the jars directly to the dependencies.
This is not to nice but maybe helps you to get further and diagnose the issue.
Btw, I will be away in about 30 minutes and will be back on monday evening.
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> some basic hibernate stuff such as create a configuration and a
>> gr. Martin
>>> anything.
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> to the class:
>>>> Manifest.MF?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> the jars that were in the "lib" directory, and we've exported each
>>>>> of them. The reexport properties of the Hibernate and Teneo
>>>>> plug-ins dependencies in the model plug-in are set. The
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Martin Taal wrote :
>>>>>> Hi Nicolas,
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> Teneo code, we're having this error message :
>>>>>>> Reason:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #57902 is a reply to message #52168] Tue, 17 October 2006 07:06 Go to previous messageGo to next message
I am also facing problems while trying to run the sample Library
application. Please find below the error message that i get.
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType, for
org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:395)
org.eclipse.example.library.presentation.LibraryEditorPlugin $Implementation.start(LibraryEditorPlugin.java:130)
I have checked all the teneo dependencies for the reexport option also.
Please let me know on what is the problem.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #57927 is a reply to message #57902] Tue, 17 October 2006 07:13 Go to previous messageGo to next message
Hi Vijayan,
Can you check if there is another underlying (or earlier) exception in the trace. My experience is
that this exception is just a signal of another exception.
gr. Martin
Vijayan wrote:
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #58805 is a reply to message #57927] Tue, 24 October 2006 01:42 Go to previous messageGo to next message
Hi Martin,
I could not see any other exception. Please find below the complete stack
trace.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #58855 is a reply to message #58805] Tue, 24 October 2006 01:52 Go to previous messageGo to next message
Hi Vijayan,
Can you post/send me the ecore file? Then I can test myself were it fails.
gr. Martin
Vijayan wrote:
> Hi Martin,
> stack trace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #58931 is a reply to message #58855] Tue, 24 October 2006 05:08 Go to previous messageGo to next message
Hi Martin,
Please find the ecore file.
<ecore:EPackage xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="library"
nsURI="http://www.example.eclipse.org/Library" nsPrefix="library">
<eClassifiers xsi:type="ecore:EClass" name="Book">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Book"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title"
unique="false" lowerBound="1"
eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String">
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="title"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pages"
http://www.eclipse.org/emf/2003/XMLType#//Int" unsettable="true">
<eAnnotations
<details key="name" value="pages"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="category"
unique="false"
lowerBound="1" eType="#//BookCategory"
defaultValueLiteral="Mystery" unsettable="true">
<eAnnotations
<details key="name" value="category"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="author"
lowerBound="1"
eType="#//Writer" eOpposite="#//Writer/books">
<eAnnotations
<details key="name" value="author"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BookCategory">
<eAnnotations
<details key="name" value="BookCategory"/>
</eAnnotations>
<eLiterals name="Mystery"/>
<eLiterals name="ScienceFiction" value="1"/>
<eLiterals name="Biography" value="2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BookCategoryObject"
instanceClassName="org.eclipse.emf.common.util.Enumerator">
<eAnnotations
<details key="name" value="BookCategory:Object"/>
<details key="baseType" value="BookCategory"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Library">
<eAnnotations
<details key="name" value="Library"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
<eAnnotations
<details key="name" value="name"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="writers"
upperBound="-1"
eType="#//Writer" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="writers"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="books"
upperBound="-1"
eType="#//Book" containment="true" resolveProxies="false">
<eAnnotations
<details key="name" value="books"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Writer">
<eAnnotations
<details key="name" value="Writer"/>
</eAnnotations>
<eAnnotations
</eAnnotations>
upperBound="-1"
eType="#//Book" eOpposite="#//Book/author">
<eAnnotations
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #58982 is a reply to message #58931] Tue, 24 October 2006 05:50 Go to previous messageGo to next message
Hi Vijayan,
This initializing correctly with me (is the standard library example).
This could be a classloading issue (teneo library is not visible to hibernate library).
I guess that all your hibernate libraries are in a separate plugin? Did you set the
eclipse-buddypolicy of this plugin to dependent? See here:
http://www.elver.org/hibernate/installation.html#Hibernate+L ibraries
Can you try to initialize the datastore outside of the editor, just in a junit test case or
something and then check if it works?
gr. Martin
Vijayan wrote:
> Hi Martin,
> xmlns:xmi="http://www.omg.org/XMI"
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> lowerBound="1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #59211 is a reply to message #58982] Wed, 25 October 2006 04:51 Go to previous messageGo to next message
Hi Martin,
Thanks that problem is solved.
I am getting the following error now.
org.eclipse.emf.teneo.hibernate.HbStoreException: Exception when saving
resource library
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadResource(HibernateResource.java:245)
org.eclipse.emf.teneo.resource.StoreResource.load(StoreResou rce.java:236)
org.eclipse.emf.teneo.resource.StoreResource.getContents(Sto reResource.java:347)
org.eclipse.example.library.presentation.LibraryModelWizard$ 1.execute(LibraryModelWizard.java:214)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
org.eclipse.example.library.presentation.LibraryModelWizard. performFinish(LibraryModelWizard.java:245)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
Caused by: org.hibernate.exception.SQLGrammarException: could not execute
query
org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:67)
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
at org.hibernate.loader.Loader.doList(Loader.java:2147)
at org.hibernate.loader.Loader.listIgnoreQueryCache(Loader.java :2028)
at org.hibernate.loader.Loader.list(Loader.java:2023)
at org.hibernate.loader.hql.QueryLoader.list(QueryLoader.java:3 93)
org.hibernate.hql.ast.QueryTranslatorImpl.list(QueryTranslat orImpl.java:338)
org.hibernate.engine.query.HQLQueryPlan.performList(HQLQuery Plan.java:172)
at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1121)
at org.hibernate.impl.QueryImpl.list(QueryImpl.java:79)
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadUsingTopClasses(HibernateResource.java:291)
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadFromStore(HibernateResource.java:277)
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadResource(HibernateResource.java:239)
... 47 more
Caused by: java.sql.SQLException: ORA-00942: table or view does not exist
at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 114)
at oracle.jdbc.ttc7.TTIoer.processError(TTIoer.java:208)
at oracle.jdbc.ttc7.Oall7.receive(Oall7.java:542)
at oracle.jdbc.ttc7.TTC7Protocol.doOall7(TTC7Protocol.java:1311 )
oracle.jdbc.ttc7.TTC7Protocol.parseExecuteDescribe(TTC7Proto col.java:595)
oracle.jdbc.driver.OracleStatement.doExecuteQuery(OracleStat ement.java:1600)
at oracle.jdbc.driver.OracleStatement.doExecute(OracleStatement .java:1758)
oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(Orac leStatement.java:1805)
oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(Ora clePreparedStatement.java:322)
oracle.jdbc.driver.OraclePreparedStatement.executeQuery(Orac lePreparedStatement.java:280)
org.hibernate.jdbc.AbstractBatcher.getResultSet(AbstractBatc her.java:186)
at org.hibernate.loader.Loader.getResultSet(Loader.java:1668)
at org.hibernate.loader.Loader.doQuery(Loader.java:662)
org.hibernate.loader.Loader.doQueryAndInitializeNonLazyColle ctions(Loader.java:224)
at org.hibernate.loader.Loader.doList(Loader.java:2144)
... 57 more
It also shows the warning
WARN main org.hibernate.util.JDBCExceptionReporter - SQL Error: 942,
SQLState: 42000
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #59262 is a reply to message #59211] Wed, 25 October 2006 11:10 Go to previous messageGo to next message
Hi Vijayan,
The tables are not present in the database, so they are not created by Hibernate. My experience is
that Hibernate will not stop if the database creation fails, the error is shown when you actually
try to use the tables.
Can you check the log why no tables are created (permission issue maybe?)?
Btw, there is a Teneo option to prevent schema update/creation: PersistenceOptions.UPDATE_SCHEMA
But as this is not part of the tutorial I don't think that you set that.
gr. Martin
Vijayan wrote:
> Hi Martin,
> resource library
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> execute query
> at
> at
> at
> at
> at
> at
> at
> ... 47 more
> at
> at
> at
> at
> at
> at
> at
> at
> ... 57 more
> SQLState: 42000
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #59539 is a reply to message #59262] Mon, 30 October 2006 05:40 Go to previous messageGo to next message
Hi Martin,
Thanks a lot. I dropped the Database schema and recreated, it works fine
now. I am able to create a library, add books and writers. But everytime i
try to change some feature and save i get the following error.
org.eclipse.emf.teneo.StoreValidationException: Diagnosis of
org.eclipse.example.library.impl.BookImpl@805550{platform:/resource/librarySample/My.library#/0/@books.2}
The required feature 'category' of
'org.eclipse.example.library.impl.BookImpl@805550{platform:/resource/librarySample/My.library#/0/@books.2}'
must be set
org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:326)
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:270)
org.eclipse.example.library.presentation.LibraryEditor$16.ex ecute(LibraryEditor.java:1370)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
I could not understand why it is not saving the value that was already set
for the category feature when i am trying to change the pages/Author
property of the book.
Also i can see the tables and the values stored in the database, but when
i execute a select query on the table i get an error saying table or view
does not exist.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #59586 is a reply to message #59539] Mon, 30 October 2006 06:02 Go to previous messageGo to next message
Hi Vijayan,
Can you try to set the bookcategory to something else than the default value before saving? It looks
similar to this old issue (url can be truncated by end-of-line):
http://www.elver.org/hibernate/troubleshooting.html#Validati on+exception+on+enumerate+properties+when+saving+the+editor+ content
This should be solved in emf 2.2.
gr. Martin
Vijayan wrote:
> Hi Martin,
> i try to change some feature and save i get the following error.
> must be set
> at
> at
> at
> at
> at
> at
> at
> set for the category feature when i am trying to change the pages/Author
> when i execute a select query on the table i get an error saying table
> or view does not exist.
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #59658 is a reply to message #59586] Mon, 30 October 2006 09:07 Go to previous message
Hi Martin,
It works fine if i change the default value to something else.
Thanks for your help.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #591612 is a reply to message #51378] Thu, 21 September 2006 10:51 Go to previous message
Hi Nicolas,
gr. Martin
> Hi Martin,
> Reason:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591700 is a reply to message #51588] Fri, 22 September 2006 04:43 Go to previous message
Hi Martin,
Martin Taal wrote :
> Hi Nicolas,
> java packages?
> gr. Martin
>> Hi Martin,
>> Reason:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Teneo : Problem with Library Editor Tutorial [message #591716 is a reply to message #51818] Fri, 22 September 2006 07:14 Go to previous message
Hi Nicolas,
gr. Martin
> Hi Martin,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote :
>> Hi Nicolas,
>> gr. Martin
>>> Hi Martin,
>>> Reason:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591720 is a reply to message #51871] Fri, 22 September 2006 07:51 Go to previous message
Martin Taal wrote :
> Hi Nicolas,
> to this issue.
> gr. Martin
>> Hi Martin,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> gr. Martin
>>>> Hi Martin,
>>>> Reason:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #591727 is a reply to message #51899] Fri, 22 September 2006 08:07 Go to previous message
Hi Nicolas,
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> to the class:
>> Manifest.MF?
>> gr. Martin
>>> Hi Martin,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> Reason:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591774 is a reply to message #51928] Fri, 22 September 2006 09:44 Go to previous message
Martin Taal wrote :
> Hi Nicolas,
> gr. Martin
>> anything.
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> to the class:
>>> Manifest.MF?
>>> gr. Martin
>>>> Hi Martin,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Martin Taal wrote :
>>>>> Hi Nicolas,
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> Reason:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #591786 is a reply to message #52115] Fri, 22 September 2006 10:00 Go to previous message
Hi Nicolas,
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> gr. Martin
>>> anything.
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> to the class:
>>>> Manifest.MF?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Martin Taal wrote :
>>>>>> Hi Nicolas,
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> Reason:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594200 is a reply to message #52168] Tue, 17 October 2006 07:06 Go to previous message
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594210 is a reply to message #57902] Tue, 17 October 2006 07:13 Go to previous message
Hi Vijayan,
gr. Martin
Vijayan wrote:
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594644 is a reply to message #57927] Tue, 24 October 2006 01:42 Go to previous message
Hi Martin,
trace.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594663 is a reply to message #58805] Tue, 24 October 2006 01:52 Go to previous message
Hi Vijayan,
gr. Martin
Vijayan wrote:
> Hi Martin,
> stack trace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594689 is a reply to message #58855] Tue, 24 October 2006 05:08 Go to previous message
Hi Martin,
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
unique="false"
<eAnnotations
</eAnnotations>
lowerBound="1"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eAnnotations
</eAnnotations>
</eClassifiers>
<eAnnotations
</eAnnotations>
</eClassifiers>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
upperBound="-1"
<eAnnotations
</eAnnotations>
upperBound="-1"
<eAnnotations
</eAnnotations>
</eClassifiers>
<eAnnotations
</eAnnotations>
<eAnnotations
</eAnnotations>
upperBound="-1"
<eAnnotations
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594702 is a reply to message #58931] Tue, 24 October 2006 05:50 Go to previous message
Hi Vijayan,
gr. Martin
Vijayan wrote:
> Hi Martin,
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> unique="false"
> <eAnnotations
> </eAnnotations>
> lowerBound="1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594796 is a reply to message #58982] Wed, 25 October 2006 04:51 Go to previous message
Hi Martin,
resource library
query
... 47 more
... 57 more
SQLState: 42000
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594810 is a reply to message #59211] Wed, 25 October 2006 11:10 Go to previous message
Hi Vijayan,
gr. Martin
Vijayan wrote:
> Hi Martin,
> resource library
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> execute query
> at
> at
> at
> at
> at
> at
> at
> ... 47 more
> at
> at
> at
> at
> at
> at
> at
> at
> ... 57 more
> SQLState: 42000
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594928 is a reply to message #59262] Mon, 30 October 2006 05:40 Go to previous message
Hi Martin,
must be set
does not exist.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594942 is a reply to message #59539] Mon, 30 October 2006 06:02 Go to previous message
Hi Vijayan,
gr. Martin
Vijayan wrote:
> Hi Martin,
> must be set
> at
> at
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594975 is a reply to message #59586] Mon, 30 October 2006 09:07 Go to previous message
Hi Martin,
Vijayan
Previous Topic:Specifying Annotations in Rose
Next Topic:Specifying Annotations in Rose
Current Time: Sun Nov 09 03:09:43 EST 2025
Powered by FUDForum. Page generated in 0.07871 seconds
