Home » Language IDEs » AspectJ » cannot open .aj files again?
cannot open .aj files again? [message #51376] Mon, 09 May 2005 11:15 Go to next message
I updated to the 1.2.0.200050503135046 build, and now I can no longer open files ending in .aj. Is this a regression bug?
java.lang.IllegalArgumentException: Compilation unit name must end with .java
at org.eclipse.jdt.internal.core.PackageFragment.getCompilation Unit(PackageFragment.java:191)
at org.eclipse.jdt.internal.core.JavaModelManager.createCompila tionUnitFrom(JavaModelManager.java:419)
at org.eclipse.jdt.core.JavaCore.createCompilationUnitFrom(Java Core.java:1263)
at home.rd.junitrunner.popup.actions.RunTestCaseAction.setActiv eEditor(RunTestCaseAction.java:53)
at org.eclipse.ui.internal.EditorPluginAction.editorChanged(Edi torPluginAction.java:82)
at org.eclipse.ui.internal.EditorPluginAction.<init>(EditorPluginAction.java:34)
at org.eclipse.ui.internal.ActionDescriptor.createAction(Action Descriptor.java:247)
at org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:167)
at org.eclipse.ui.internal.ViewerActionBuilder.createActionDesc riptor(ViewerActionBuilder.java:53)
at org.eclipse.ui.internal.PluginActionBuilder.readElement(Plug inActionBuilder.java:155)
at org.eclipse.ui.internal.ViewerActionBuilder.readElement(View erActionBuilder.java:102)
at org.eclipse.ui.internal.registry.RegistryReader.readElements (RegistryReader.java:138)
at org.eclipse.ui.internal.registry.RegistryReader.readElementC hildren(RegistryReader.java:127)
at org.eclipse.ui.internal.PluginActionBuilder.readElement(Plug inActionBuilder.java:139)
at org.eclipse.ui.internal.registry.RegistryReader.readExtensio n(RegistryReader.java:148)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry (RegistryReader.java:168)
at org.eclipse.ui.internal.PluginActionBuilder.readContribution s(PluginActionBuilder.java:111)
at org.eclipse.ui.internal.ViewerActionBuilder.readViewerContri butions(ViewerActionBuilder.java:119)
at org.eclipse.ui.internal.PopupMenuExtender.readStaticActions( PopupMenuExtender.java:253)
at org.eclipse.ui.internal.PopupMenuExtender.<init>(PopupMenuExtender.java:79)
at org.eclipse.ui.internal.PartSite.registerContextMenu(PartSit e.java:277)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2583)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:303)
at org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.createPart Control(JavaEditor.java:2647)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .createPartControl(CompilationUnitEditor.java:1608)
at org.eclipse.ajdt.internal.ui.editor.AspectJEditor.createPart Control(AspectJEditor.java:353)
at org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1237)
at org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
at org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1648)
at org.eclipse.ui.internal.EditorManager$Editor.getPart(EditorM anager.java:1639)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:26 0)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.select(PresentablePartFolder.java:268)
at org.eclipse.ui.internal.presentations.newapi.LeftToRightTabO rder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.newapi.TabbedStackPres entation.selectPart(TabbedStackPresentation.java:391)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1070)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1019)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 23)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:406)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
at org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:267)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:829)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:809)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:697)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:660)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2236)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2165)
at org.eclipse.ui.internal.WorkbenchPage.access$7(WorkbenchPage .java:2157)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2143)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2138)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:231)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:129)
at org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 0)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:212)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:188)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:304)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:805)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:658)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:656)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:875)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:974)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.mouseSelectItem(OpenSt rategy.java:402)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:340)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: cannot open .aj files again? [message #51405 is a reply to message #51376] Mon, 09 May 2005 11:29 Go to previous message
I reverted back to the previous build and the problem is gone. But I'm not sure if there might have been two versions of ajdt installed. I upgraded via the install site. But that does not remove the old version. And when I looked in platform.xml, it seemed to contain references to both versions.
I must admit, that I seem to have trouble with updating plugins via update sites. Where using link files seems to be fully reliable. Is it just me?
-barry
Re: cannot open .aj files again? [message #588011 is a reply to message #51376] Mon, 09 May 2005 11:29 Go to previous message
-barry
Previous Topic:cannot open .aj files again?
Next Topic:Eclipse Hangs After Installing AJDT
Current Time: Thu Nov 06 06:27:42 EST 2025
Powered by FUDForum. Page generated in 0.03779 seconds
