| Executing SQL statement [message #51367] |
Tue, 11 November 2008 12:08  |
Originally posted by: andi.hotz.adsl.li
Up until now when I was interested in the contents of a table I accessed
the contents through an SQL statement using the java.sql.* package.
With DTP this is something like the flowing:
IConnectionProfile profile;
String sql = "select * from some_table";
Connection conn = (Connection)
profile.createConnection("java.sql.Connection").getRawConnection();
try {
Statement stmt = conn.createStatement();
ResultSet rs = stmt.executeQuery(sql);
if (rs.next()){
// something found found so do something
} else {
// nothing found so do something else
} catch (SQLException e){
e.printStackTrace();
I noticed there are classes/interfaces like
org.eclipse.datatools.modelbase.sql.query.impl.QuerySelectSt atementImpl.
How can I make use of this to access the data in my database table while
ignoring the underling connection infrastructure (JDBC connection will
only work if the data source driver is a JDBC driver).
So here is the question: How do I access my data in an abstract way?
I hope someone has some helpful thoughts.
Cheers
Andy
| Re: Executing SQL statement [message #51479 is a reply to message #51423] |
Wed, 12 November 2008 14:52  |
Thanks for your tips
I had a look at ODA and found a lot of interfaces and could construct an
example to get my data starting from an IDriver. I could not figure out
how to retrieve any instance of this interface. Is there a way?
I also had a quick look at Eclipselink and Dali. Eclipselink is
certainly interesting but with the vocal point on databases perhaps not
the best choice. Dali seems a bit heavy weight with the installation of
an application server for JPA. I figure the interesting classes are in
the package org.eclipse.jpt.db. What I'm not sure about is if I can use
these classes without JPA since persistence is not my main focus.
So thanks again for your input
Andy
Shaun Smith wrote:
> Brian Payton wrote:
>> If you want to work with your table data at a level of abstraction
>> above JDBC, you might want to look at the ODA (Open Data Access)
>> component of DTP. Other possibilities are non-Eclipse frameworks such
>> as Spring and Hibernate.
> You certainly don't need to use Non-Eclipse frameworks for this. :-)
> EclipseLink provides the Java Persistence API 2.0 reference
> implementation and is available as either a set of OSGi bundles or as a
> plain Java jar. If you're looking for object-relational mapping then
> check out EclipseLink and the Eclipse Dali Java Persistence Tools
> project for intelligent design time tooling.
> --Shaun
> http://www.eclipse.org/eclipselink
> http://www.eclipse.org/dali
> NB: Dali uses DTP for database and schema information!
| Re: Executing SQL statement [message #593821 is a reply to message #51367] |
Tue, 11 November 2008 21:25  |
The Query model classes such as QuerySelectStatement are not really
intended to be used to access the data in your tables. They are used to
analyze and build SQL statements, particularly DML (Select, Insert,
Update, Delete).
If you want to work with your table data at a level of abstraction above
JDBC, you might want to look at the ODA (Open Data Access) component of
DTP. Other possibilities are non-Eclipse frameworks such as Spring and
Hibernate.
> try {
> if (rs.next()){
> } else {
> Cheers
> Andy
| Re: Executing SQL statement [message #593829 is a reply to message #51395] |
Wed, 12 November 2008 10:24  |
> Hibernate.
EclipseLink provides the Java Persistence API 2.0 reference implementation
and is available as either a set of OSGi bundles or as a plain Java jar.
If you're looking for object-relational mapping then check out EclipseLink
and the Eclipse Dali Java Persistence Tools project for intelligent design
time tooling.
--Shaun
| Re: Executing SQL statement [message #593872 is a reply to message #51423] |
Andy
> --Shaun
FUDForum. Page generated in 0.06909 seconds
