Home » Eclipse Projects » Plugin Development Environment (PDE) » RCP Export Problems -- "Unable to acquire application service"
RCP Export Problems -- "Unable to acquire application service" [message #51363] Sat, 21 March 2009 14:37 Go to next message
--------------070809080608020406070802
(Apologies for the cross post...please let me know if this was better
suited in one newsgroup over another)
I was seeing this problem in a separate application that I was trying to
export, but I also see it when creating a brand new headless RCP app
using the "Hello World" template.
First off, I created the new app and a launch config using only those
plugins deemed required by the system. When I attempt to run, I get the
trace listed as "Trace 1" below. After manually adding the
org.eclipse.update.configurator plugin, the launch runs successfully.
Next I created a product (HelloWorld.product) based off of the launch
config and tried to export it. Everything seems to export fine, but
when I run the eclipse.exe file, I get the "Trace 2" trace.
Would anyone have an idea as to whether or not there is something that
I'm doing wrong? I've got the sample app that I can send if need be.
Thanks in advance,
Jesse
*Trace 1:*
!SESSION 2009-03-21 12:14:23.437
eclipse.buildId=unknown
java.version=1.6.0_05
Framework arguments: -product HelloWorld.product
Command-line arguments: -product HelloWorld.product -data
C:\dev\ChiroPOS2/../runtime-HelloWorld.product -dev
file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties
-os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.109
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.IllegalArgumentException: The System Bundle's start level can
not be modified.
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1122)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:646)
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:623)
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!MESSAGE
!STACK 0
not be modified.
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.125
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Platform not running
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
Trace 2:
*!SESSION 2009-03-21 12:05:43.000
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:05:43.781
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
<html>
<head>
</head>
suited in one newsgroup over another)<br>
<br>
to export, but I also see it when creating a brand new headless RCP app
using the "Hello World" template.<br>
<br>
plugins deemed required by the system.&nbsp; When I attempt to run, I get
the trace listed as "Trace 1" below.&nbsp; After manually adding the
org.eclipse.update.configurator plugin, the launch runs successfully.<br>
<br>
config and tried to export it.&nbsp; Everything seems to export fine, but
when I run the eclipse.exe file, I get the "Trace 2" trace.<br>
<br>
I'm doing wrong?&nbsp; I've got the sample app that I can send if need be.<br>
<br>
Thanks in advance,<br>
&nbsp;Jesse<br>
<br>
<b>Trace 1:</b><br>
<br>
-----------------------------------------------<br>
eclipse.buildId=unknown<br>
java.version=1.6.0_05<br>
java.vendor=Sun Microsystems Inc.<br>
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US<br>
Framework arguments:&nbsp; -product HelloWorld.product<br>
Command-line arguments:&nbsp; -product HelloWorld.product -data
<a class="moz-txt-link-freetext" href=" file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties "> file:C:/dev/ChiroPOS2/.metadata/.plugins/org.eclipse.pde.cor e/HelloWorld.product/dev.properties </a>
-os win32 -ws win32 -arch x86<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.109<br>
!MESSAGE An unexpected runtime error has occurred.<br>
!STACK 0<br>
not be modified.<br>
&nbsp;&nbsp;&nbsp; at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1122) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:646) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:623) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308) <br>
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234) <br>
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211) <br>
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141) <br>
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518) <br>
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469) <br>
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281) <br>
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247) <br>
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201) <br>
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644) <br>
org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175) <br>
&nbsp;&nbsp;&nbsp; at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
&nbsp;&nbsp;&nbsp; at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<br>
&nbsp;&nbsp;&nbsp; at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)<br>
&nbsp;&nbsp;&nbsp; at java.lang.reflect.Method.invoke(Unknown Source)<br>
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) <br>
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)<br >
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.run(Main.java:1236)<br>
&nbsp;&nbsp;&nbsp; at org.eclipse.equinox.launcher.Main.main(Main.java:1212)<br>
<br>
!MESSAGE <br>
!STACK 0<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:14:24.125<br>
!MESSAGE Application error<br>
!STACK 1<br>
java.lang.IllegalStateException: Platform not running<br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179) <br>
<br>
<br>
<br>
<b><br>
Trace 2:<br>
<br>
</b>!SESSION 2009-03-21 12:05:43.000
Command-line arguments:&nbsp; -os win32 -ws win32 -arch x86<br>
<br>
!ENTRY org.eclipse.osgi 4 0 2009-03-21 12:05:43.781<br>
!STACK 1<br>
(see config.ini).<br>
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74) <br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386) <br>
<br>
</body>
</html>
--------------070809080608020406070802--
Re: RCP Export Problems -- "Unable to acquire application service" [message #51391 is a reply to message #51363] Sat, 21 March 2009 16:26 Go to previous messageGo to next message
> Thanks in advance,
> Jesse
1. Whats your eclipse version?
2. Did you try using RCP cheatsheet instead?
Ankur..
Re: RCP Export Problems -- "Unable to acquire application service" [message #51419 is a reply to message #51391] Sat, 21 March 2009 18:40 Go to previous messageGo to next message
>> app using the "Hello World" template.
>> the trace listed as "Trace 1" below. After manually adding the
>> that I'm doing wrong? I've got the sample app that I can send if
>> need be.
>> Thanks in advance,
>> Jesse
3.4.2
No. Are you talking in terms of using the org.eclipse.ui.cheatsheets
plugin somehow?
Thanks for your help,
Jesse
Re: RCP Export Problems -- "Unable to acquire application service" [message #51447 is a reply to message #51363] Sat, 21 March 2009 20:06 Go to previous messageGo to next message
What version of Eclipse are you using? What version of Eclipse are you
targetting in your target platform?
~ Chris
Re: RCP Export Problems -- "Unable to acquire application service" [message #51475 is a reply to message #51447] Sat, 21 March 2009 20:14 Go to previous messageGo to next message
>> need be.
3.4.2 for both.
Jesse
Re: RCP Export Problems -- "Unable to acquire application service" [message #51502 is a reply to message #51475] Sun, 22 March 2009 07:26 Go to previous messageGo to next message
--------------070503060200030905080303
After a week of researching, I think I found my needle in the haystack.
After trying the same thing out with an SR1 build, I noticed that in my
config.ini file, the start level for SR1 was:
*org.eclipse.core.runtime@start*
where my 3.4.2 export was:
*org.eclipse.core.runtime@2:start*
After making the change in my 3.4.2 exported application to match that
of the SR1 one, things seemed to work fine.
I'm curious, though, if anyone else is seeing this problem in 3.4.2 or
if it's just me.
Thanks for reading,
Jesse
>>> better suited in one newsgroup over another)
>>> trying to export, but I also see it when creating a brand new
>>> headless RCP app using the "Hello World" template.
>>> those plugins deemed required by the system. When I attempt to run,
>>> I get the trace listed as "Trace 1" below. After manually adding
>>> the org.eclipse.update.configurator plugin, the launch runs
>>> successfully.
>>> launch config and tried to export it. Everything seems to export
>>> fine, but when I run the eclipse.exe file, I get the "Trace 2" trace.
>>> need be.
>> you targetting in your target platform?
> 3.4.2 for both.
> Jesse
<html>
<head>
</head>
haystack.&nbsp; :-)&nbsp; <br>
<br>
config.ini file, the start level for SR1 was:<br>
<br>
<b>org.eclipse.core.runtime@start</b><br>
<br>
where my 3.4.2 export was:<br>
<br>
<b>org.eclipse.core.runtime@2:start</b><br>
<br>
of the SR1 one, things seemed to work fine.<br>
<br>
if it's just me.<br>
<br>
Thanks for reading,<br>
&nbsp;Jesse<br>
<br>
<blockquote cite="mid:gq3vsu$80k$1@build.eclipse.org" type="cite">Chris
Aniszczyk wrote:
<br>
<blockquote type="cite">Jesse Riggins wrote:
<br>
<blockquote type="cite">(Apologies for the cross post...please let
me know if this was better suited in one newsgroup over another)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
3.4.2 for both. <br>
<br>
Jesse
<br>
</blockquote>
<br>
</body>
</html>
--------------070503060200030905080303--
Re: RCP Export Problems -- "Unable to acquire application service" [message #51528 is a reply to message #51419] Sun, 22 March 2009 14:09 Go to previous message
> plugin somehow?
No. I am referring to Help -> CheatSheats -> Plugin Development -> Creating an RCP App.
Ankur..
Re: RCP Export Problems -- "Unable to acquire application service" [message #593700 is a reply to message #51363] Sat, 21 March 2009 16:26 Go to previous message
> Thanks in advance,
> Jesse
Ankur..
Re: RCP Export Problems -- "Unable to acquire application service" [message #593707 is a reply to message #51391] Sat, 21 March 2009 18:40 Go to previous message
>> need be.
>> Thanks in advance,
>> Jesse
3.4.2
plugin somehow?
Jesse
Re: RCP Export Problems -- "Unable to acquire application service" [message #593720 is a reply to message #51363] Sat, 21 March 2009 20:06 Go to previous message
~ Chris
Re: RCP Export Problems -- "Unable to acquire application service" [message #593729 is a reply to message #51447] Sat, 21 March 2009 20:14 Go to previous message
>> need be.
3.4.2 for both.
Jesse
Re: RCP Export Problems -- "Unable to acquire application service" [message #593736 is a reply to message #51475] Sun, 22 March 2009 07:26 Go to previous message
if it's just me.
Thanks for reading,
Jesse
>>> successfully.
>>> need be.
> 3.4.2 for both.
> Jesse
<html>
<head>
</head>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&nbsp;Jesse<br>
<br>
Aniszczyk wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
Jesse
<br>
</blockquote>
<br>
</body>
</html>
Re: RCP Export Problems -- "Unable to acquire application service" [message #593750 is a reply to message #51419] Sun, 22 March 2009 14:09 Go to previous message
> plugin somehow?
Ankur..
Previous Topic:RCP Export Problems -- "Unable to acquire application service"
Next Topic:getPackageFragmentRoots does not return dependent workspace plugins
Current Time: Sun Nov 30 19:19:59 EST 2025
Powered by FUDForum. Page generated in 0.06686 seconds
