Home » Modeling » TMF (Xtext) » Rich text styling in a Xtext-generated editor
Rich text styling in a Xtext-generated editor [message #51351] Sun, 14 June 2009 15:57 Go to next message
I am building a structured text editor, but with similar formatting
capabilities as wikitext permits. The formatting can be implied from the
grammar (e.g. no need to mix two languages), but it needs to be displayed
in a rich fashion (syntax highlighting won't do). I also need bind to
other EMF models, hence I am investigating whether to use Xtext. I know
the domain is somewhat apart from Xtext (e.g. Mylyn Wikitext might be
closer), but I would still like to hear your opinion & tips.
I know StyledText component can display rich text display, such as
bulleted lists, different fonts etc. Is this possible with Xtext-derived
editors?
Furthermore, I would like to hide some tokens from display. I have
understood that it could not be done by projection document (as I were
able to hide full lines only, not a few words) - do you have any solution
for this in Xtext (e.g. exclude some tokens from the viewer)?
Thanks in advance,
Lauri
Re: Rich text styling in a Xtext-generated editor [message #51613 is a reply to message #51351] Mon, 15 June 2009 18:19 Go to previous message
You can use different fonts in Xtext, but I don't know how to do bullet
lists. Also the standard Xtext editor displays the chars of the
resource, not a textual projection of an in-memory model.
However, as Xtext supports bi-directional mapping between text and model
(hence we have a parser as well as a serializer) it should be possible
to do this. Don't know how good it would "feel" in the end.
Sven
Lauri Svan schrieb:
> displayed in a rich fashion (syntax highlighting won't do). I also need
> bind to other EMF models, hence I am investigating whether to use Xtext.
> I know the domain is somewhat apart from Xtext (e.g. Mylyn Wikitext
> might be closer), but I would still like to hear your opinion & tips.
> editors?
> solution for this in Xtext (e.g. exclude some tokens from the viewer)?
> Thanks in advance,
> Lauri
Previous Topic:Workflow Problem
Next Topic:Importing a grammar which inturn has imported a Metamodel
Current Time: Sat Nov 08 17:59:16 EST 2025
Powered by FUDForum. Page generated in 0.02455 seconds
