| Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » OCL generation templates: getEAllOperations() vs. getEOperations()
 Goto Forum:|
| OCL generation templates: getEAllOperations() vs. getEOperations() [message #51321] | Wed, 20 September 2006 15:24  |  |
| Eclipse User  |  |  |  |  | Originally posted by: acv.modeldrivendevelopment.co.uk
 Dear Christian,
 Please let me know if this has already been fixed or posted.
 I have a metamodel with a validation operation validateName(DiagnosticChain,
 Map):Boolean
 in an abstract superclass NamedElement.
 When this validation is executed on an instance of a subtype,
 the generated code in the validateName method fails,
 when attempting to retrieve the operation by index.
 The index is out of bounds of the eOperations of the receiver class,
 because the index used to retrieve the operation is relative to the
 list of operations of the implementing class (NamedElement, index = 0),
 and not to list of operations in the receiver class.
 Furthermore, even if the receiver class had enough operations to avoid the
 out-of-bounds condition,
 it would retrieve another operation - no the expected one - possibly without
 ocl and/or invariant.
 The original generated code was:
 public boolean validatePrimaryKeyColumnsTable(DiagnosticChain diagnostics,
 Map context) {
 if (validatePrimaryKeyColumnsTableInvOCL == null) {
 EOperation eOperation = (EOperation) eClass().getEOperations().get(1);
 After correction of the templates:
 Map context) {
 EOperation eOperation = (EOperation) eClass().getEAllOperations().get(1);
 genOperation.override.javajetinc used to read:
 if (<%=expr%> == null) {
 <%=genModel.getImportedName("org.eclipse.emf.ecore.EOperation ")%> eOperation
 = (<%=genModel.getImportedName("org.eclipse.emf.ecore.EOperation ")%>)
 eClass().getEOperations().get(< %=eOperation.getEContainingClass().getEOperations().indexOf( eOperation)% >);
 now it reads:
 eClass().getEAllOperations().get(< %=eOperation.getEContainingClass().getEAllOperations().index Of(eOperation)% >);
 I have also changed all the similar uses in the templates of
 getEOperations() with getEAllOperations(), and getEEstructuralFeatures()
 with getEAllEstructuralFeatures().
 Antonio Carrasco-Valero
 Model Driven Developement, SL
| Re: OCL generation templates: getEAllOperations() vs. getEOperations() [message #51488 is a reply to message #51321] | Thu, 21 September 2006 09:05   |  |
| Eclipse User  |  |  |  |  | Originally posted by: cdamus.ca.ibm.com
 Hi, Antonio,
 Thanks for catching that!  I don't think I used an Ecore model having EClass
 specializations in developing my article, so I never noticed this problem.
 I suppose that there is some process for following up articles with errata
 or revisions.  I'll have to see what I can do.  In the mean-time, hopefully
 everyone who is using those templates sees your posting, here.
 Thanks again!
 Christian
 Antonio Carrasco Valero wrote:
 > Dear Christian,
 > validateName(DiagnosticChain, Map):Boolean
 > without ocl and/or invariant.
 > Map context) {
 > Map context) {
 > eOperation =
 > now it reads:
 > eOperation =
| OCL validation in subclasses: error fix [message #51607 is a reply to message #51488] | Thu, 21 September 2006 11:09  |  |
 Thanks, Christian,
 I hope you don't minf that I have re-posted with new subject,
 as the previous:
 is too obscure to be of any help for whom may look for a solution.
 Model Driven Development SL
 "Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
 news:eeu2m3$qg9$1@utils.eclipse.org...
 > Hi, Antonio,
 > EClass
 > hopefully
 > Thanks again!
 > Christian
 >> Dear Christian,
 >> the
 >> diagnostics,
 >> Map context) {
 >> diagnostics,
 >> Map context) {
 >> eOperation =
 >> now it reads:
 >> eOperation =
 >> Thanks,
| Re: OCL generation templates: getEAllOperations() vs. getEOperations() [message #591582 is a reply to message #51321] | Thu, 21 September 2006 09:05  |  |
 Hi, Antonio,
 Thanks again!
 Christian
 > Dear Christian,
 > Map context) {
 > Map context) {
 > eOperation =
 > now it reads:
 > eOperation =
| OCL validation in subclasses: error fix [message #591620 is a reply to message #51488] | Thu, 21 September 2006 11:09  |  |
 Thanks, Christian,
 as the previous:
 > Hi, Antonio,
 > EClass
 > hopefully
 > Thanks again!
 > Christian
 >> Dear Christian,
 >> the
 >> diagnostics,
 >> Map context) {
 >> diagnostics,
 >> Map context) {
 >> eOperation =
 >> now it reads:
 >> eOperation =
 >> Thanks,
 Current Time: Thu Oct 30 20:37:38 EDT 2025
 Powered by FUDForum . Page generated in 0.04199 seconds |
