Home » Archived » M2M (model-to-model transformation) » [ATL] ATL projector
[ATL] ATL projector [message #51316] Sun, 08 July 2007 04:44 Go to next message
Originally posted by: basgraaf.tudelft.nl
Hi All,
I am having problems with the ATL injector. As an example consider
ATLCopier.atl from the KM32ATLCopier transformation from the zoo. When I
inject:
module Copy;
create OUT : MM from IN : MM;
rule CopyTest {
from
s : MM!Test
s.oclIsTypeOf(MM!Test)
to
t : MM!Test (
name <- s.name,
description <- s.description
and subsequently extract the resulting model, I get:
module Copy;
rule CopyTest {
from
s : MM!Test
to
t : MM!Test (
name <-.name,
description <-.description
The variable expressions disappeared in the output pattern (s). It seems
that the problem is that the referredVariable feature of the
variableExpression is not set by the injector (see fragment of injection
result below). When I correct this manually, the extracted ATL code is
as expected.
I am using
http://www.sciences.univ-nantes.fr/lina/atl/www/atldemo/adt_ am3.zip. Has
anybody observed this behaviour before?
Thanks for any help,
Kind regards,
Bas Graaf.
<outPattern location="10:3-14:6">
<elements xsi:type="atl:SimpleOutPatternElement" location="11:5-14:6"
varName="t">
<type xsi:type="ocl:OclModelElement" location="11:9-11:16"
name="Test" model="/1"/>
<bindings location="12:7-12:21" propertyName="name">
<value xsi:type="ocl:NavigationOrAttributeCallExp"
location="12:15-12:21" name="name">
<source xsi:type="ocl:VariableExp" location="12:15-12:16"
name="s"/>
</value>
</bindings>
<bindings location="13:7-13:35" propertyName="description">
location="13:22-13:35" name="description">
<source xsi:type="ocl:VariableExp" location="13:22-13:23"
name="s"/>
</value>
</bindings>
</elements>
</outPattern>
Re: [ATL] ATL projector [message #51537 is a reply to message #51316] Mon, 09 July 2007 05:13 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Bas Graaf a écrit :
> Hi All,
Hi Bas,
> inject:
> module Copy;
> rule CopyTest {
> from
> s : MM!Test
> to
> t : MM!Test (
> name <- s.name,
> module Copy;
> rule CopyTest {
> from
> s : MM!Test
> to
> t : MM!Test (
> name <-.name,
> as expected.
> I am using
The version you're using is quite old. You may try to use the latest
version of ATL & AM3 and I think it should work.
See
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg01185.html
for getting install instructions.
> Kind regards,
> Bas Graaf.
> varName="t">
> name="s"/>
> </value>
> </bindings>
> name="s"/>
> </value>
> </bindings>
> </elements>
> </outPattern>
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
Re: [ATL] ATL projector [message #51760 is a reply to message #51537] Tue, 10 July 2007 02:33 Go to previous messageGo to next message
Hi Hugo,
Now it works. Thanks!
As a follow-up question:
Is it possible to invoke the ATL extractor from an ANT build script?
This is not working:
<am3.saveModel model="ATLModel" path="${targetModels}ATLFile.atl" >
<extractor name="atl"/>
</am3.saveModel>
Kind regards,
Bas.
Hugo Bruneliere wrote:
> Bas Graaf a écrit :
>> Hi All,
> Hi Bas,
>> I inject:
>> module Copy;
>> rule CopyTest {
>> from
>> s : MM!Test
>> to
>> t : MM!Test (
>> name <- s.name,
>> module Copy;
>> rule CopyTest {
>> from
>> s : MM!Test
>> to
>> t : MM!Test (
>> name <-.name,
>> seems that the problem is that the referredVariable feature of the
>> injection result below). When I correct this manually, the extracted
>> ATL code is as expected.
>> I am using
>> Has anybody observed this behaviour before?
> See
>> Kind regards,
>> Bas Graaf.
>> location="11:5-14:6" varName="t">
>> name="s"/>
>> </value>
>> </bindings>
>> name="s"/>
>> </value>
>> </bindings>
>> </elements>
>> </outPattern>
> Best regards,
> Hugo
Re: [ATL] ATL projector [message #51789 is a reply to message #51760] Tue, 10 July 2007 04:39 Go to previous message
Bas Graaf a écrit :
> Hi Hugo,
Hi Bas,
> </am3.saveModel>
In order to do that using ANT tasks, you have to proceed in several steps:
1) Load the TCS metamodel (available from the org.eclipse.am3.core
plugin, into "resources/TCS/")
<am3.loadModel modelHandler="EMF" name="TCS" metamodel="MOF"
path="TCS.ecore">
2) Load the TCS model for ATL (also available from the
org.eclipse.am3.core plugin, but into "resources/ATL-0.2/")
<am3.loadModel modelHandler="EMF" name="ATL-TCS" metamodel="TCS"
path="ATL-0.2-TCS.ecore">
3) Finally extract your ATL model into an ATL file using this TCS model:
<am3.saveModel model="ATLModel" path="${targetModels}ATLFile.atl">
<extractor name="ebnf">
<param name="format" value="ATL-TCS"/>
<param name="indentString" value=" "/>
<param name="serializeComments" value="false"/>
</extractor>
</am3.saveModel>
Hugo
> Kind regards,
> Bas.
>> Bas Graaf a écrit :
>>> Hi All,
>> Hi Bas,
>>> When I inject:
>>> module Copy;
>>> rule CopyTest {
>>> from
>>> s : MM!Test
>>> to
>>> t : MM!Test (
>>> name <- s.name,
>>> module Copy;
>>> rule CopyTest {
>>> from
>>> s : MM!Test
>>> to
>>> t : MM!Test (
>>> name <-.name,
>>> I am using
>> See
>>> Kind regards,
>>> Bas Graaf.
>>> name="s"/>
>>> </value>
>>> </bindings>
>>> name="s"/>
>>> </value>
>>> </bindings>
>>> </elements>
>>> </outPattern>
>> Best regards,
>> Hugo
Previous Topic:[ATL] General Question XML2XML
Next Topic:[ATL] how to get more error message when transformation failed?
Current Time: Sun Nov 23 02:56:28 EST 2025
Powered by FUDForum. Page generated in 0.31992 seconds
