Home » Archived » XML Schema Definition (XSD) » How to retrieve Attributes for a complex ElementDeclaration
How to retrieve Attributes for a complex ElementDeclaration [message #51267] Mon, 23 August 2004 17:51 Go to next message
Originally posted by: gj.puredge.com
Given the schema fragment:
<xsd:element name="Test">
<xsd:complexType>
<xsd:choice>
<xsd:element ref="comment"></xsd:element>
<xsd:element name="choice2" type="xsd:string"></xsd:element>
</xsd:choice>
<xsd:attribute name="Attribute" type="xsd:string"></xsd:attribute>
</xsd:complexType>
</xsd:element>
From the complexType particle, getTerm() gets the "choice" ModelGroup.
Which method gets the attribute(s)?
Sorry for such a newbie question.
Re: How to retrieve Attributes for a complex ElementDeclaration [message #51293 is a reply to message #51267] Mon, 23 August 2004 23:15 Go to previous messageGo to next message
Originally posted by: gj.pureedge.com
I think I found what I need. Here's some code I wrote to print out
attributes for an element. Correct me if I'm wrong.
Starting with: ElementDeclaration element
XSDTypeDefinition type = element.getTypeDefinition();
if (type instanceof XSDComplexTypeDefinition)
EList list = ((XSDComplexTypeDefinition) type).getAttributeContents();
for (Iterator iter = list.iterator(); iter.hasNext();)
Object obj = iter.next();
if (obj instanceof XSDAttributeUse)
XSDAttributeUse a = (XSDAttributeUse) obj;
System.out.println(a.getAttributeDeclaration().getName());
I'm not sure if the results of getAttributeContents() are always an instance
of XSDAttributeUse so I check just in case.
Re: How to retrieve Attributes for a complex ElementDeclaration [message #51458 is a reply to message #51293] Tue, 24 August 2004 07:48 Go to previous messageGo to next message
Gary,
Yes, the contents will always be of type XSDAttributeUse, so there's no
need for a instanceof check. Note that getAttributeContents returns the
physically contained attribute declarations whereas getAttributeUses
will get the inherited ones as well as the local ones just as getContent
returns the physically contained content model (particle/simple type)
whereas getContentType will return the inherited content model as well.
Re: How to retrieve Attributes for a complex ElementDeclaration [message #51512 is a reply to message #51458] Tue, 24 August 2004 10:32 Go to previous messageGo to next message
Thanks Ed,
getAttributeContents vs getAttributeUses
Am I correct that this is another example of the difference between the
"Concrete" and "Abstract" representations of the schema?
The Concrete representation is what's actually written in the schema file
itself whereas Abstract is (sort of) the "expanded" version of the schema
with all the inherited types, groups, refs, etc available.
I'd use the Concrete model if I wanted to serialize (write) the schema and
the Abstract to walk the schema elements, among other things.
I think I'm actually starting to get a clue. That perhaps qualifies me a
"cluebie" .
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cgf9ov$ujg$1@eclipse.org...
Gary,
>instance
Re: How to retrieve Attributes for a complex ElementDeclaration [message #51538 is a reply to message #51512] Tue, 24 August 2004 10:37 Go to previous messageGo to next message
--------------020405000909090205010801
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
Yes, that's exactly right. ;-)
Gary J wrote:
>Thanks Ed,
>"cluebie" .
>Gary,
>>instance
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
Yes, that's exactly right. ;-)<br>
<br>
<br>
Gary J wrote:<br>
<blockquote cite="midcgfjbg$i5q$1@eclipse.org" type="cite">
<pre wrap="">Thanks Ed,
"cluebie" .
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:cgf9ov$ujg$1@eclipse.org">news:cgf9ov$ujg$1@eclipse.org</a>...
Gary,
Gary J wrote:
</pre>
<blockquote type="cite">
<pre wrap="">I think I found what I need. Here's some code I wrote to print out
instance
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------020405000909090205010801--
attribute use from declaration [message #54280 is a reply to message #51538] Wed, 27 October 2004 02:49 Go to previous messageGo to next message
Sorry to drop this question..may be stupid one
How can one get XSDAttributeUse for an attribute from attributedeclaration.
best
roy
Ed Merks wrote:
> Gary,
> Gary J wrote:
>>Thanks Ed,
>>"cluebie" .
>>Gary,
>>>instance
Re: attribute use from declaration [message #54307 is a reply to message #54280] Wed, 27 October 2004 13:00 Go to previous message
Roy,
If the attribute use is not the container
(XSDConcreteComponent.getContainer()) of the attribute declaration, then
there isn't a way since there can be arbitrarily many attributes uses
that share a particular attribute declaration (because they have "ref"
to it).
> best
> roy
> Ed Merks wrote:
>> Gary,
>> Gary J wrote:
>>> Thanks Ed,
>>> the "Concrete" and "Abstract" representations of the schema?
>>> file itself whereas Abstract is (sort of) the "expanded" version of
>>> the schema with all the inherited types, groups, refs, etc available.
>>> schema and the Abstract to walk the schema elements, among other
>>> things.
>>> me a "cluebie" .
>>> Gary,
>>> the
>>> getContent
>>>> instance
Re: How to retrieve Attributes for a complex ElementDeclaration [message #590790 is a reply to message #51267] Mon, 23 August 2004 23:15 Go to previous message
Re: How to retrieve Attributes for a complex ElementDeclaration [message #590923 is a reply to message #51293] Tue, 24 August 2004 07:48 Go to previous message
Gary,
Re: How to retrieve Attributes for a complex ElementDeclaration [message #590953 is a reply to message #51458] Tue, 24 August 2004 10:32 Go to previous message
Thanks Ed,
"cluebie" .
Gary,
>instance
Re: How to retrieve Attributes for a complex ElementDeclaration [message #590966 is a reply to message #51512] Tue, 24 August 2004 10:37 Go to previous message
Gary,
Gary J wrote:
>Thanks Ed,
>"cluebie" .
>Gary,
>>instance
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
<br>
Gary J wrote:<br>
"cluebie" .
Gary,
Gary J wrote:
</pre>
instance
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
attribute use from declaration [message #592228 is a reply to message #51538] Wed, 27 October 2004 02:49 Go to previous message
best
roy
Ed Merks wrote:
> Gary,
> Gary J wrote:
>>Thanks Ed,
>>"cluebie" .
>>Gary,
>>>instance
Re: attribute use from declaration [message #592249 is a reply to message #54280] Wed, 27 October 2004 13:00 Go to previous message
Roy,
to it).
> best
> roy
> Ed Merks wrote:
>> Gary,
>> Gary J wrote:
>>> Thanks Ed,
>>> things.
>>> me a "cluebie" .
>>> Gary,
>>> the
>>> getContent
>>>> instance
Previous Topic:XSD and WTP relationships
Next Topic:EMF-based DOM
Current Time: Tue Nov 04 08:56:39 EST 2025
Powered by FUDForum. Page generated in 0.69947 seconds
