Home » Modeling » TMF (Xtext) » Workflow Problem
Workflow Problem [message #51242] Sun, 14 June 2009 12:21 Go to next message
I am relatively new to xText and began with the oAW release, and have
migrated my code to tmf now. My grammar seems fine but when I generate a
concrete model I get a workflow error.
What could be the problem? Thanks in advance for any tips.
My grammar:
grammar org.xtext.example.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/MyDsl"
//Our ORM2 Model
Model:
(elements+=Element)*;
//Elements can be Objects or Predicates
Element:
Object_Type | Predicate;
//Objects are Entities or Values
Object_Type:
Entity_Type | Value_Type (IsPrimitive?="subtype"
supertype=[Object_Type])?;
//Entities
Entity_Type:
"entity" name=ID (IsPrimitive?="subtype" supertype=[Object_Type])? "{"
(IsNested?="nests" Predicate=[Predicate])?
("definition" def=STRING)?
("subconstr" sub=STRING)?
("role" role=STRING Predicate=[Predicate])*
//Value is a DataType or not
Value_Type:
("value" type=[DataType|ID] name=ID) | DataType (IsPrimitive?="subtype")?;
//DataTypes includes Integer, String, Boolean...
DataType:
"datatype" name=ID;
//Predicate
Predicate:
"predicate" name=ID "{"
"part" (Participants+=Participant)+
(Arity=Arity ";")?
(IsDerived?="derived" ";")?
//Participants in the predicate
Participant:
type=[Object_Type];
//Arity
Arity:
"arity" name=INT;
My test model:
entity student{}
entity person{}
entity professor{
nests teaches
definition "he teaches"
subconst "alot"
entity teacher subtype person{}
predicate teaches {
part professor student
arity 3;
derived;
I get the error:
2016 [main] ERROR org.eclipse.xpand2.Generator - Error in
Component of type org.eclipse.xpand2.Generator:
EvaluationException : Couldn't find property 'elements' for type
myDsl::Model
templates::Template.xpt[110,13] on line 8 'this.elements'
[23,42] on line 1 'EXPAND templates::Template::main FOR model'
2016 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - Workflow
interrupted. Reason: Couldn't find property 'elements' for type
myDsl::Model
2032 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: Couldn't
find property 'elements' for type myDsl::Model(Element: this.elements;
Reported by: Generator: generating 'templates::Template::main FOR model'
org.eclipse.internal.xpand2.ast.ForEachStatement@1493102; Reported by:
Generator: generating 'templates::Template::main FOR model' => [])
org.eclipse.internal.xpand2.ast.FileStatement@30ae41; Reported by:
find property 'elements' for type myDsl::Model(Element: main : Model;
find property 'elements' for type myDsl::Model(Element: EXPAND
templates::Template::main FOR model; Reported by: Generator: generating
Re: Workflow Problem [message #51322 is a reply to message #51242] Sun, 14 June 2009 15:48 Go to previous messageGo to next message
Originally posted by: peter.friese.itemis.com
Aurel,
could you also please post your template, as this seems to be the place
the error ocurrs?
Peter
On 2009-06-14 18:21:19 +0200, aurel_ganga@yahoo.com (Aurel Ganga) said:
> Hello,
> a concrete model I get a workflow error.
> My grammar:
> //Our ORM2 Model
> Model:
> Element:
> Object_Type:
> Entity_Type | Value_Type (IsPrimitive?="subtype" supertype=[Object_Type])?;
> //Entities
> Entity_Type:
> "{" (IsNested?="nests" Predicate=[Predicate])? ("definition"
> def=STRING)?
> ("role" role=STRING Predicate=[Predicate])* "}";
> Value_Type:
> DataType:
> "datatype" name=ID;
> //Predicate Predicate:
> (Arity=Arity ";")? (IsDerived?="derived" ";")?
> Participant:
> type=[Object_Type];
> //Arity Arity:
> "arity" name=INT;
> My test model:
> entity student{}
> entity person{}
> entity professor{
> nests teaches
> subconst "alot"
> predicate teaches {
> arity 3;
> derived;
> I get the error:
> Component of type org.eclipse.xpand2.Generator: EvaluationException :
> Couldn't find property 'elements' for type myDsl::Model
> templates::Template.xpt[110,13] on line 8 'this.elements' [23,42]
> myDsl::Model
> Couldn't find property 'elements' for type myDsl::Model(Element:
> this.elements; Reported by: Generator: generating
> Couldn't find property 'elements' for type myDsl::Model(Element: main :
> Model; Reported by: Generator: generating 'templates::Template::main
> FOR model' => [])
> Couldn't find property 'elements' for type myDsl::Model(Element: EXPAND
Re: Workflow Problem [message #51379 is a reply to message #51242] Sun, 14 June 2009 16:49 Go to previous messageGo to next message
My Template is the default one, havent changed anything.
«IMPORT myDsl»;
«EXTENSION templates::Extensions»
«DEFINE main FOR Model»
«FILE "output.txt"-»
«FOREACH this.elements AS e»
«e.name» («e.metaType») «e.referencedBy()»
«ENDFOREACH-»
«ENDFILE»
«ENDDEFINE»
My Extensions file is also almost the default, but with a part commented
out because it gave another error:
import myDsl;
//referencedBy(Class this) :
// this.eRootContainer.eAllContents.typeSelect(Class).select(e| e.references
== this).name.toString(",");
After some minor code optimization and tampering, the error is:
3016 [main] ERROR org.eclipse.xpand2.Generator - Error in
EvaluationException : Couldn't find operation 'referencedBy()' for
myDsl::Entity_Type.
templates::Template.xpt[158,16] on line 9 'e.referencedBy()'
3016 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - Workflow
interrupted. Reason: Couldn't find operation 'referencedBy()' for
myDsl::Entity_Type.
3016 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: Couldn't
find operation 'referencedBy()' for myDsl::Entity_Type.(Element:
e.referencedBy(); Reported by: Generator: generating
EXPRESSION: e.referencedBy(); Reported by: Generator: generating
org.eclipse.internal.xpand2.ast.ForEachStatement@b20352; Reported by:
org.eclipse.internal.xpand2.ast.FileStatement@f8395f; Reported by:
find operation 'referencedBy()' for myDsl::Entity_Type.(Element: main :
Model; Reported by: Generator: generating 'templates::Template::main FOR
model' => [])
find operation 'referencedBy()' for myDsl::Entity_Type.(Element: EXPAND
It seems as the problem is in the template still, but i haven't changed
the default at all. Maybe i have to change the template?
Re: Workflow Problem [message #51434 is a reply to message #51322] Mon, 15 June 2009 05:17 Go to previous messageGo to next message
The errors appear in Template.xpt and Extensions.ext, both are the default
files created by the project. They look like this:
Template:
«IMPORT myDsl»;
«DEFINE main FOR Model-»
«FOREACH this.elements.typeSelect(Element).sortBy(e|e.name) AS e-»
«e.name» has «e.listSubclasses()».
«ENDFOREACH-»
«ENDFILE-»
«ENDDEFINE»
Extensions:
import myDsl;
listSubclasses(Class this) :
let subclasses =
this.eRootContainer.eAllContents.typeSelect(Class).select(e| e.superClass
== this).name:
switch (subclasses.size) {
case 0: "no subclasses"
case 1: "subclass: " + subclasses.toString(", ")
default: subclasses.size.toString() + " subclasses: " +
My model/grammar no rule/entity contains the keyword "class" (nor is
called that way).
At workflow runtime I get the error that starts like this (is much longer):
2328 [main] ERROR org.eclipse.xpand2.Generator - Error in
EvaluationException : Couldn't resolve type for 'Class'. Did you forget
to configure the corresponding metamodel?
templates::Extensions.ext[15,333] on line 3 'listSubclasses(Class this)'
2328 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - Workflow
interrupted. Reason: Couldn't resolve type for 'Class'. Did you forget to
2328 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]:
Diagnosis of
org.xtext.example.myDsl.impl.ModelImpl@1d88db7{classpath:/model/MyModel.mydsl#/}(Element:
org.xtext.example.myDsl.impl.ModelImpl@1d88db7; Reported by: MweReader:
loading file from classpath:/model/MyModel.mydsl)
2328 [main] ERROR eclipse.emf.mwe.core.WorkflowRunner - [ERROR]: Couldn't
find operation 'allElements()' for myDsl::Entity_Type.(Element:
EvaluationException : Couldn't find operation 'allElements()' for
myDsl::Entity_Type.
Any tips?
Re: Workflow Problem [message #51516 is a reply to message #51434] Mon, 15 June 2009 05:55 Go to previous messageGo to next message
Aurel,
> default files created by the project. They look like this:
The template and the extension look exactly right - they match the
*original* version of the DSL (containing concepts like Class and
DataType). Xtext can not derive templates and extensions from a given
grammar. It probably could, but this would entirely miss the point.
Only you know what to do with a model and how to transform the model
into somethin meaningful. That's the whole point of a DSL.
> called that way).
Right - as I pointed out, Xtext does not derive the template form your grammar.
> Couldn't resolve type for 'Class'. Did you forget to configure the
> Diagnosis of
> myDsl::Entity_Type.(Element: EvaluationException : Couldn't find
> Any tips?
Yes - start writing your own template :-) Xpand (the language used to
write templates) is documented here:
http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/core_reference.html#xpand_reference_introducti on
Peter
Re: Workflow Problem [message #51542 is a reply to message #51379] Mon, 15 June 2009 06:00 Go to previous messageGo to next message
Aurel,
> commented out because it gave another error:
> import myDsl;
> Couldn't find operation 'referencedBy()' for myDsl::Entity_Type.
> templates::Template.xpt[158,16] on line 9 'e.referencedBy()' [23,42]
No, the problem is in the extension. As you commented out the extension
"referencedBy()", there is extension named "referencedBy()" any more
and thus you're getting an error when invoking this non-existing
extension from your template.
Maybe you could point out what you're trying to achieve so we can help you.
Peter
Re: Workflow Problem [message #51567 is a reply to message #51516] Mon, 15 June 2009 06:24 Go to previous message
I am still new to Xtext so I did not fully realise what the template must
do.
Thank you very much for the pointers.
Previous Topic:Uniqueness Check
Next Topic:Rich text styling in a Xtext-generated editor
Current Time: Sun Nov 30 15:04:05 EST 2025
Powered by FUDForum. Page generated in 0.05241 seconds
