Home » Archived » BPMN Modeler » why remove sequence flow's attribute:source
why remove sequence flow's attribute:source [message #4504] Mon, 08 December 2008 22:14 Go to next message
Hi guys,
I found that in 2.0.0M3 version, *.bpmn file, the source and target
attributes of sequence edges are removed. But in 1.0.1 version, they were
at there.
Who can tell me the reason? For redundance with other nodes?
And I know in the bpmn emf model, the sequence edges class has getSource()
method.
Now Can I yet use the sequenceedge.getSource() method?
Grid
Re: why remove sequence flow's attribute:source [message #4574 is a reply to message #4504] Tue, 09 December 2008 03:49 Go to previous message
Originally posted by: atoulme.intalio.com
It's only removed in the xml.
It was duplicated before, and that was the source of problems. Now
sources and targets are kept on the vertices only, and it is computed
when the file is loaded.
Antoine
grid.qian wrote:
> Hi guys,
> were at there.
> getSource() method.
> Thanks
> Grid
Previous Topic:general Overview (project current situation)
Next Topic:add property to an activity
Current Time: Fri Nov 07 02:10:23 EST 2025
Powered by FUDForum. Page generated in 0.09691 seconds
