Home » Archived » XML Schema Definition (XSD) » XSD Enumeration issue
XSD Enumeration issue [message #51185] Mon, 23 August 2004 08:21 Go to next message
Originally posted by: alastair.dunsmore.mottmac.com
I have a small problem with some EEnum Literals not appearing for an
annotation. This is highlighted in the following sample:
<?xml version = "1.0" encoding = "UTF-8"?>
<xsd:schema xmlns:xsd = "http://www.w3.org/2001/XMLSchema">
<xsd:attribute name = "Direction">
<xsd:annotation>
<xsd:documentation>Direction</xsd:documentation>
</xsd:annotation>
<xsd:simpleType>
<xsd:restriction base = "xsd:string">
<xsd:enumeration value = "Circular"/>
<xsd:enumeration value = "Clockwise"/>
<xsd:enumeration value = "Anti-Clockwise"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:attribute>
</xsd:schema>
If I import this via XSD into eclipse, then the generated Ecore does not
have EEnum Literals - instead i get a Key-Value pair with the
Key="enumeration" and Value has a space delimited string of the
Enumerations. If the 3rd enumeration, "Anti-Clockwise" is commented out
it works as expected. Is the "-" character causing this? Is this
character illegal in this usage context or is this a problem with XSD?
I am currenly using XSD v200408120834.
Thanks for you help,
Alastair Dunsmore
Re: XSD Enumeration issue [message #51216 is a reply to message #51185] Mon, 23 August 2004 09:26 Go to previous message
--------------010401030703030403080701
Content-Type: text/plain; charset=us-ascii; format=flowed
Alastair,
An EEnum is generated only if every enumeration value is a valid Java
identifier:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/overviews/XMLSchemaToEcoreMapping.pdf
> <xsd:annotation>
> </xsd:annotation>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
></xsd:schema>
>Regards,
>Alastair Dunsmore
Content-Type: text/html; charset=us-ascii
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Alastair,<br>
<br>
identifier:<br>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/overviews/XMLSchemaToEcoreMapping.pdf"> http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/overviews/XMLSchemaToEcoreMapping.pdf</a><br>
</blockquote>
<br>
<br>
Alastair Dunsmore wrote:<br>
<blockquote cite="midcgcng0$v2a$1@eclipse.org" type="cite">
<pre wrap="">I have a small problem with some EEnum Literals not appearing for an
&lt;?xml version = "1.0" encoding = "UTF-8"?&gt;
&lt;xsd:schema xmlns:xsd = <a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>&gt;
&lt;xsd:attribute name = "Direction"&gt;
&lt;xsd:annotation&gt;
&lt;xsd:documentation&gt;Direction&lt;/xsd:docum entation&gt;
&lt;/xsd:annotation&gt;
&lt;xsd:simpleType&gt;
&lt;xsd:restriction base = "xsd:string"&gt;
&lt;xsd:enumeration value = "Circular"/&gt;
&lt;xsd:enumeration value = "Clockwise"/&gt;
&lt;xsd:enumeration value = "Anti-Clockwise"/&gt;
&lt;/xsd:restriction&gt;
&lt;/xsd:simpleType&gt;
&lt;/xsd:attribute&gt;
&lt;/xsd:schema&gt;
Alastair Dunsmore
</pre>
</blockquote>
<br>
</body>
</html>
--------------010401030703030403080701--
Re: XSD Enumeration issue [message #590724 is a reply to message #51185] Mon, 23 August 2004 09:26 Go to previous message
Alastair,
identifier:
> <xsd:annotation>
> </xsd:annotation>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
></xsd:schema>
>Regards,
>Alastair Dunsmore
<html>
<head>
<title></title>
</head>
Alastair,<br>
<br>
identifier:<br>
<blockquote><a
</blockquote>
<br>
<br>
&lt;/xsd:schema&gt;
Alastair Dunsmore
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:XSD Enumeration issue
Next Topic:What about the future of XSDEdit?
Current Time: Mon Jul 14 12:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.16184 seconds
